Data sheet
3412.8 FAP 2,5/4A YE
End plate, Width: 1.5 mm, Colour: Yellow
RAL: 1026
Business data
Article number
3412.8
Article name
FAP 2,5/4A YE
GTIN (EAN)
4044211110499
Packaging unit
Quantity unit
PC
Weight per piece (not including packaging)
3.2 g
Weight per piece (including packaging)
3.3 g
Unit of weight
G
Customs number
85389099
Country of origin
DE
Prio-Article
3412.2
Product description
End plate
Creation date 17.12.2023 08:39:14
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
77.7 mm
Width
1.5 mm
Height
31.5 mm
Materials
Material
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Environmental Product Compliance
REACH Candidate Substance Note
No
2
Data sheet
Media
3
Data sheet
Accessories
##INVERSE##CONTA-CONNECT
Protective earth terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5,
Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3215.2
FSL 2,5/4A GNYE
4044211110154
100 ST
Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5,
Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3212.2
FRK 2,5/4A BG
4044211109868
100
4
很抱歉,暂时无法提供与“3412.8”相匹配的价格&库存,您可以联系我们找货
