3450.9
3450.9
    CONTA-CLIP
    INSULATED CROSS CONNECTOR
3450.9 数据手册
Data sheet 3450.9 FQI 1,5/10 RD Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 40.9 mm, Colour: Red Business data Article number 3450.9 Article name FQI 1,5/10 RD GTIN (EAN) 4044211113292 Packaging unit 10 Quantity unit PC Weight per piece (not including packaging) 5.2 g Weight per piece (including packaging) 5.3 g Unit of weight G Customs number 85389099 Country of origin CZ Prio-Article 3450.8 Product description Insulated cross-connector Creation date 17.12.2023 08:39:02 Subject to technical changes 1 Data sheet 3450.9 FQI 1,5/10 RD Technical data Dimensions Length 4 mm Width 40.9 mm Pitch size 4.1 mm Ratings Max. voltage 800 V Rated current 17.5 A Current load, max. 17,5 A Rated cross-section 1.5 mm² Connection data No. of poles 10 Materials Material Copper Surface Tin-nickel Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Plug in Insulation available Touch protection is available Number of bridged terminals 10 Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 08:39:02 No Subject to technical changes 2 Data sheet 3450.9 FQI 1,5/10 RD Media Creation date 17.12.2023 08:39:02 Subject to technical changes 3 Data sheet 3450.9 FQI 1,5/10 RD Accessories ##INVERSE##CONTA-CONNECT Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 4.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3202.2 FRK 1,5/4A BG 4044211109684 100 Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 4.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3200.2 FRK 1,5/2A BG 4044211109530 100 Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 4.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3201.2 FRK 1,5/3A BG 4044211109615 100 ##INVERSE##CONTA-CONNECT Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 4.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3201.2 FRK 1,5/3A BG 4044211109615 100 Creation date 17.12.2023 08:39:02 Subject to technical changes 4
3450.9 价格&库存
很抱歉,暂时无法提供与“3450.9”相匹配的价格&库存,您可以联系我们找货
