Data sheet
3453.4 FQI 1,5/3 BK
Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 12.2 mm, Colour: Black
RAL: 9005
Business data
Article number
3453.4
Article name
FQI 1,5/3 BK
GTIN (EAN)
4044211113391
Packaging unit
50
Quantity unit
PC
Weight per piece (not including packaging)
1.4 g
Weight per piece (including packaging)
1.5 g
Unit of weight
G
Customs number
85389099
Country of origin
CZ
Prio-Article
3453.8
Product description
Creation date 17.12.2023 08:39:15
Subject to technical changes
1
Data sheet
3453.4 FQI 1,5/3 BK
Technical data
Dimensions
Length
4 mm
Width
12.2 mm
Pitch size
4.1 mm
Ratings
Max. voltage
800 V
Rated current
17.5 A
Current load, max.
17,5 A
Rated cross-section
1.5 mm²
Connection data
No. of poles
3
Materials
Material
Copper
Surface
Tin-nickel
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Mounting type
Plug in
Insulation available
Touch protection is available
Number of bridged terminals
3
Environmental Product Compliance
REACH Candidate Substance Note
No
2
Data sheet
3453.4 FQI 1,5/3 BK
Media
3
Data sheet
3453.4 FQI 1,5/3 BK
Accessories
##INVERSE##CONTA-CONNECT
Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5,
Rated cross-section: 1.5 mm², Width: 4.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3202.2
FRK 1,5/4A BG
4044211109684
100
Article number
Article name
GTIN (EAN)
Packaging
unit
3200.2
FRK 1,5/2A BG
4044211109530
100
Article number
Article name
GTIN (EAN)
Packaging
unit
3201.2
FRK 1,5/3A BG
4044211109615
100
Article number
Article name
GTIN (EAN)
Packaging
unit
3201.2
FRK 1,5/3A BG
4044211109615
100
4
很抱歉,暂时无法提供与“3453.4”相匹配的价格&库存,您可以联系我们找货
