3458.9
3458.9
    CONTA-CLIP
    INSULATED CROSS CONNECTOR
3458.9 数据手册
Data sheet 3458.9 FQI 1,5/8 RD Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 32.7 mm, Colour: Red Business data Article number 3458.9 Article name FQI 1,5/8 RD GTIN (EAN) 4044211113896 Packaging unit 10 Quantity unit PC Weight per piece (not including packaging) 4g Weight per piece (including packaging) 4.1 g Unit of weight G Customs number 85389099 Country of origin CZ Prio-Article 3458.8 Product description Insulated cross-connector Creation date 17.12.2023 05:16:35 Subject to technical changes 1 Data sheet 3458.9 FQI 1,5/8 RD Technical data Dimensions Length 4 mm Width 32.7 mm Pitch size 4.1 mm Ratings Max. voltage 800 V Rated current 17.5 A Current load, max. 17,5 A Rated cross-section 1.5 mm² Connection data No. of poles 8 Materials Material Copper Surface Tin-nickel Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Plug in Insulation available Touch protection is available Number of bridged terminals 8 Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 05:16:35 No Subject to technical changes 2 Data sheet 3458.9 FQI 1,5/8 RD Media Creation date 17.12.2023 05:16:35 Subject to technical changes 3 Data sheet 3458.9 FQI 1,5/8 RD Accessories ##INVERSE##CONTA-CONNECT Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 4.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3202.2 FRK 1,5/4A BG 4044211109684 100 Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 4.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3200.2 FRK 1,5/2A BG 4044211109530 100 Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 4.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3201.2 FRK 1,5/3A BG 4044211109615 100 ##INVERSE##CONTA-CONNECT Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 4.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3201.2 FRK 1,5/3A BG 4044211109615 100 Creation date 17.12.2023 05:16:35 Subject to technical changes 4
3458.9
物料型号: - 文章编号:3458.9 - 文章名称:FQI 1,5/8 RD - GTIN(EAN):4044211113896 - 包装单位:10 - 重量每件(不含包装):4g
器件简介: - 绝缘交叉连接器,8个极,插头式安装,宽度32.7毫米,颜色为红色
引脚分配: - 极数:8
参数特性: - 长度:4毫米 - 宽度:32.7毫米 - 节距:4.1毫米 - 最大电压:800V - 额定电流:17.5A - 材料:铜(表面镀锡镍) - 绝缘外壳材料:聚酰胺6.6
功能详解: - 工作温度范围:-40°C至105°C - 插头式安装 - 触电保护可用 - 8个桥接端子
应用信息: - 符合REACH候选物质说明:无
封装信息: - 产品描述:绝缘交叉连接器 - 原产国:捷克
3458.9 价格&库存
很抱歉,暂时无法提供与“3458.9”相匹配的价格&库存,您可以联系我们找货
