Data sheet
3460.5 FQI 2,5/10 BU
Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 50.9 mm, Colour: Blue
RAL: Ähnlich 5005
Business data
Article number
3460.5
Article name
FQI 2,5/10 BU
GTIN (EAN)
4044211113704
Packaging unit
10
Quantity unit
PC
Weight per piece (not including packaging)
6.8 g
Weight per piece (including packaging)
6.9 g
Unit of weight
G
Customs number
85389099
Country of origin
CZ
Prio-Article
3460.8
Product description
Creation date 15.12.2023 02:15:38
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
4 mm
Width
50.9 mm
Pitch size
5.1 mm
Ratings
Max. voltage
800 V
Rated current
24 A
Current load, max.
24 A
Rated cross-section
2.5 mm²
Connection data
No. of poles
10
Materials
Material
Copper
Surface
Tin-nickel
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Mounting type
Plug in
Insulation available
Touch protection is available
Number of bridged terminals
10
Environmental Product Compliance
REACH Candidate Substance Note
No
2
Data sheet
Media
3
Data sheet
Accessories
##INVERSE##CONTA-CONNECT
Double-level terminal with electronic components, Push-in connection, Mounting type:
Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3230.2
FRKD 2,5/D1 BG
4044211130091
100
Article number
Article name
GTIN (EAN)
Packaging
unit
3237.2
FRKD 2,5/LED1(RD) 24V DC BG
4044211131876
100 ST
Article number
Article name
GTIN (EAN)
Packaging
unit
3238.2
FRKD 2,5/LED2(RD) 24V DC BG
4044211131883
100 ST
Article number
Article name
GTIN (EAN)
Packaging
unit
3253.2
FRKD 2,5/D2 BG
4044211131838
100 ST
Article number
Article name
GTIN (EAN)
Packaging
unit
3254.2
FRKD 2,5/D3 BG
4044211131845
100 ST
Article number
Article name
GTIN (EAN)
Packaging
unit
3255.2
FRKD 2,5/D4 BG
4044211131852
100 ST
4
Data sheet
Article number
Article name
GTIN (EAN)
Packaging
unit
3256.2
FRKD 2,5/D5 BG
4044211131869
100 ST
Fuse-disconnect terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5,
Article number
Article name
GTIN (EAN)
Packaging
unit
3268.2
FTRK 2,5/3A/ZS BG
4044211138011
100
Basic terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated crosssection: 2.5 mm², Width: 5.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3257.2
FTRK 2,5/2A/OT BG
4044211137687
100
Disconnect-blade terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5,
Article number
Article name
GTIN (EAN)
Packaging
unit
3259.2
FTRK 2,5/2A/MT BG
4044211137748
100
Article number
Article name
GTIN (EAN)
Packaging
unit
3260.2
FTRK 2,5/3A/MT BG
4044211137779
100
Article number
Article name
GTIN (EAN)
Packaging
unit
3263.2
FTRK 2,5/2A/ZS BG
4044211137847
100
5
Data sheet
Article number
Article name
GTIN (EAN)
Packaging
unit
3258.2
FTRK 2,5/3A/OT BG
4044211137717
100
Disconnect terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated
Article number
Article name
GTIN (EAN)
Packaging
unit
3261.2
FTRK 2,5/2A/ST BG
4044211137809
100
Article number
Article name
GTIN (EAN)
Packaging
unit
3262.2
FTRK 2,5/3A/ST BG
4044211137823
100
Initiator terminal / actuator terminal, Push-in connection, Mounting type: Mounting rail TS
Article number
Article name
GTIN (EAN)
Packaging
unit
3295.2
FIK 2,5/3 BG
4044211190095
100 ST
Article number
Article name
GTIN (EAN)
Packaging
unit
3296.2
FIK 2,5/3/LED(RD) BG
4044211190118
100 ST
Double-level terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated
Article number
Article name
GTIN (EAN)
Packaging
unit
3227.2
FRKD 2,5/SV BG
4044211130060
100
6
Data sheet
Double-level terminal connected vertically with housing pegs, block variant, Push-in
connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width:
Article number
Article name
GTIN (EAN)
Packaging
unit
3232.2
FRKD 2,5 SV-BL BG
4044211130114
50 ST
Article number
Article name
GTIN (EAN)
Packaging
unit
3206.2
FRKD 2,5/3A BG
4044211206970
50
Article number
Article name
GTIN (EAN)
Packaging
unit
3207.2
FRKD 2,5/3A/SV BG
4044211207007
50
Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3219.2
FRKD 2,5/3A/SV MI BG
4044211209957
50 ST
Article number
Article name
GTIN (EAN)
Packaging
unit
3226.2
FRKD 2,5 BG
4044211130053
100
Article number
Article name
GTIN (EAN)
Packaging
unit
3228.2
FRKD 2,5/Z BG
4044211130077
50 ST
7
Data sheet
Article number
Article name
GTIN (EAN)
Packaging
unit
3229.2
FRKD 2,5 SV/Z BG
4044211130084
50 ST
Double-level terminal with housing pegs, block variant, Push-in connection, Mounting
type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour:
Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3231.2
FRKD 2,5-BL BG
4044211130107
50 ST
Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3218.2
FRKD 2,5/3A MI BG
4044211209940
50 ST
Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5,
Article number
Article name
GTIN (EAN)
Packaging
unit
3211.2
FRK 2,5/3A BG
4044211109806
100
Article number
Article name
GTIN (EAN)
Packaging
unit
3210.2
FRK 2,5/2A BG
4044211109745
100
8
Data sheet
Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5,Rated
Article number
Article name
GTIN (EAN)
Packaging
unit
3212.2
FRK 2,5/4A BG
4044211109868
100
Article number
Article name
GTIN (EAN)
Packaging
unit
3230.2
FRKD 2,5/D1 BG
4044211130091
100
Article number
Article name
GTIN (EAN)
Packaging
unit
3253.2
FRKD 2,5/D2 BG
4044211131838
100 ST
Article number
Article name
GTIN (EAN)
Packaging
unit
3238.2
4044211131883
100 ST
9
