3467.5
3467.5
    CONTA-CLIP
    INSULATED CROSS CONNECTOR
3467.5 数据手册
Data sheet 3467.5 FQI 2,5/7 BU Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 35.6 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 3467.5 Article name FQI 2,5/7 BU GTIN (EAN) 4044211113766 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 4.6 g Weight per piece (including packaging) 4.7 g Unit of weight G Customs number 85389099 Country of origin CZ Prio-Article 3467.8 Product description Insulated cross-connector Creation date 16.12.2023 12:40:22 Subject to technical changes 1 Data sheet 3467.5 FQI 2,5/7 BU Technical data Dimensions Length 4 mm Width 35.6 mm Pitch size 5.1 mm Ratings Max. voltage 800 V Rated current 24 A Current load, max. 24 A Rated cross-section 2.5 mm² Connection data No. of poles 7 Materials Material Copper Surface Tin-nickel Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Plug in Insulation available Touch protection is available Number of bridged terminals 7 Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 12:40:22 No Subject to technical changes 2 Data sheet 3467.5 FQI 2,5/7 BU Media Creation date 16.12.2023 12:40:22 Subject to technical changes 3 Data sheet 3467.5 FQI 2,5/7 BU Accessories ##INVERSE##CONTA-CONNECT Double-level terminal with electronic components, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3230.2 FRKD 2,5/D1 BG 4044211130091 100 Double-level terminal with electronic components, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3237.2 FRKD 2,5/LED1(RD) 24V DC BG 4044211131876 100 ST Double-level terminal with electronic components, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3238.2 FRKD 2,5/LED2(RD) 24V DC BG 4044211131883 100 ST Double-level terminal with electronic components, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3253.2 FRKD 2,5/D2 BG 4044211131838 100 ST Double-level terminal with electronic components, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3254.2 FRKD 2,5/D3 BG 4044211131845 100 ST Double-level terminal with electronic components, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3255.2 FRKD 2,5/D4 BG 4044211131852 100 ST Creation date 16.12.2023 12:40:22 Subject to technical changes 4 Data sheet 3467.5 FQI 2,5/7 BU ##INVERSE##CONTA-CONNECT Double-level terminal with electronic components, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3256.2 FRKD 2,5/D5 BG 4044211131869 100 ST Fuse-disconnect terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3268.2 FTRK 2,5/3A/ZS BG 4044211138011 100 Basic terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated crosssection: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3257.2 FTRK 2,5/2A/OT BG 4044211137687 100 Disconnect-blade terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3259.2 FTRK 2,5/2A/MT BG 4044211137748 100 Disconnect-blade terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3260.2 FTRK 2,5/3A/MT BG 4044211137779 100 Fuse-disconnect terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3263.2 FTRK 2,5/2A/ZS BG 4044211137847 100 Creation date 16.12.2023 12:40:22 Subject to technical changes 5 Data sheet 3467.5 FQI 2,5/7 BU ##INVERSE##CONTA-CONNECT Basic terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated crosssection: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3258.2 FTRK 2,5/3A/OT BG 4044211137717 100 Disconnect terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3261.2 FTRK 2,5/2A/ST BG 4044211137809 100 Disconnect terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3262.2 FTRK 2,5/3A/ST BG 4044211137823 100 Initiator terminal / actuator terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3295.2 FIK 2,5/3 BG 4044211190095 100 ST Initiator terminal / actuator terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3296.2 FIK 2,5/3/LED(RD) BG 4044211190118 100 ST Double-level terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3227.2 FRKD 2,5/SV BG 4044211130060 100 Creation date 16.12.2023 12:40:22 Subject to technical changes 6 Data sheet 3467.5 FQI 2,5/7 BU ##INVERSE##CONTA-CONNECT Double-level terminal connected vertically with housing pegs, block variant, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3232.2 FRKD 2,5 SV-BL BG 4044211130114 50 ST Double-level terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3206.2 FRKD 2,5/3A BG 4044211206970 50 Double-level terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3207.2 FRKD 2,5/3A/SV BG 4044211207007 50 Double-level terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3219.2 FRKD 2,5/3A/SV MI BG 4044211209957 50 ST Double-level terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3226.2 FRKD 2,5 BG 4044211130053 100 Double-level terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3228.2 FRKD 2,5/Z BG 4044211130077 50 ST Creation date 16.12.2023 12:40:22 Subject to technical changes 7 Data sheet 3467.5 FQI 2,5/7 BU ##INVERSE##CONTA-CONNECT Double-level terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3229.2 FRKD 2,5 SV/Z BG 4044211130084 50 ST Double-level terminal with housing pegs, block variant, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3231.2 FRKD 2,5-BL BG 4044211130107 50 ST Double-level terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3218.2 FRKD 2,5/3A MI BG 4044211209940 50 ST Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3211.2 FRK 2,5/3A BG 4044211109806 100 Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3210.2 FRK 2,5/2A BG 4044211109745 100 Creation date 16.12.2023 12:40:22 Subject to technical changes 8 Data sheet 3467.5 FQI 2,5/7 BU ##INVERSE##CONTA-CONNECT Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5,Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3212.2 FRK 2,5/4A BG 4044211109868 100 ##INVERSE##CONTA-CONNECT Double-level terminal with electronic components, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3230.2 FRKD 2,5/D1 BG 4044211130091 100 ##INVERSE##CONTA-CONNECT Double-level terminal with electronic components, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3253.2 FRKD 2,5/D2 BG 4044211131838 100 ST ##INVERSE##CONTA-CONNECT Double-level terminal with electronic components, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3238.2 FRKD 2,5/LED2(RD) 24V DC BG 4044211131883 100 ST Creation date 16.12.2023 12:40:22 Subject to technical changes 9
3467.5 价格&库存
很抱歉,暂时无法提供与“3467.5”相匹配的价格&库存,您可以联系我们找货
