3470.8
3470.8
    CONTA-CLIP
    INSULATED CROSS CONNECTOR
3470.8 数据手册
Data sheet 3470.8 FQI 4/10 YE Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 60.9 mm, Colour: Yellow RAL: 1026 Business data Article number 3470.8 Article name FQI 4/10 YE GTIN (EAN) 4044211110819 Packaging unit 10 Quantity unit PC Weight per piece (not including packaging) 7.49 g Weight per piece (including packaging) 7.51 g Unit of weight G Customs number 85389099 Country of origin CZ Prio-Article 3470.8 Product description Insulated cross-connector Creation date 16.12.2023 01:19:41 Subject to technical changes 1 Data sheet 3470.8 FQI 4/10 YE Technical data Dimensions Length 4 mm Width 60.9 mm Pitch size 6.1 mm Ratings Max. voltage 800 V Rated current 32 A Current load, max. 32 A Rated cross-section 4 mm² Connection data No. of poles 10 Materials Material Copper Surface Tin-nickel Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Plug in Insulation available Touch protection is available Number of bridged terminals 10 Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 01:19:41 No Subject to technical changes 2 Data sheet 3470.8 FQI 4/10 YE Media Creation date 16.12.2023 01:19:41 Subject to technical changes 3 Data sheet 3470.8 FQI 4/10 YE Accessories ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3290.4 FSIK 4/2A BK 4044211180287 25 ST Fuse-disconnect terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3291.4 FSIK 4/2A/LED 12-30V AC/DC BK 4044211188962 25 ST Disconnect-blade terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3239.4 FSIK 4/2A/MT BK 4044211209933 50 ST Fuse-disconnect terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3292.4 FSIK 4/2A/LED 30-60V AC/DC BK 4044211188979 25 ST Fuse-disconnect terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3293.4 FSIK 4/2A/LED 110-250V AC/DC BK 4044211188986 25 ST Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3221.2 FRK 4/3A BG 4044211109981 100 Creation date 16.12.2023 01:19:41 Subject to technical changes 4 Data sheet 3470.8 FQI 4/10 YE ##INVERSE##CONTA-CONNECT Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3222.2 FRK 4/4A BG 4044211110048 100 Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3220.2 FRK 4/2A BG 4044211109929 100 Creation date 16.12.2023 01:19:41 Subject to technical changes 5
3470.8 价格&库存
很抱歉,暂时无法提供与“3470.8”相匹配的价格&库存,您可以联系我们找货
