Data sheet
3473.9 FQI 4/3 RD
Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 18.2 mm, Colour: Red
Business data
Article number
3473.9
Article name
FQI 4/3 RD
GTIN (EAN)
4044211114022
Packaging unit
50
Quantity unit
PC
Weight per piece (not including packaging)
2.14 g
Weight per piece (including packaging)
2.16 g
Unit of weight
G
Customs number
85389099
Country of origin
CZ
Prio-Article
3473.8
Product description
Creation date 16.12.2023 00:21:02
Subject to technical changes
1
Data sheet
3473.9 FQI 4/3 RD
Technical data
Dimensions
Length
4 mm
Width
18.2 mm
Pitch size
6.1 mm
Ratings
Max. voltage
800 V
Rated current
32 A
Current load, max.
32 A
Rated cross-section
4 mm²
Connection data
No. of poles
3
Materials
Material
Copper
Surface
Tin-nickel
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Mounting type
Plug in
Insulation available
Touch protection is available
Number of bridged terminals
3
Environmental Product Compliance
REACH Candidate Substance Note
No
2
Data sheet
3473.9 FQI 4/3 RD
Media
3
Data sheet
3473.9 FQI 4/3 RD
Accessories
##INVERSE##CONTA-CONNECT
Fuse-disconnect terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5,
Rated cross-section: 4 mm², Width: 6 mm, Colour: Black
Article number
Article name
GTIN (EAN)
Packaging
unit
3290.4
FSIK 4/2A BK
4044211180287
25 ST
Article number
Article name
GTIN (EAN)
Packaging
unit
3291.4
FSIK 4/2A/LED 12-30V AC/DC BK
4044211188962
25 ST
Disconnect-blade terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5,
Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Black
Article number
Article name
GTIN (EAN)
Packaging
unit
3239.4
FSIK 4/2A/MT BK
4044211209933
50 ST
Article number
Article name
GTIN (EAN)
Packaging
unit
3292.4
FSIK 4/2A/LED 30-60V AC/DC BK
4044211188979
25 ST
Article number
Article name
GTIN (EAN)
Packaging
unit
3293.4
FSIK 4/2A/LED 110-250V AC/DC BK
4044211188986
25 ST
Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5,
Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3221.2
FRK 4/3A BG
4044211109981
100
4
Data sheet
3473.9 FQI 4/3 RD
Article number
Article name
GTIN (EAN)
Packaging
unit
3222.2
FRK 4/4A BG
4044211110048
100
Article number
Article name
GTIN (EAN)
Packaging
unit
3220.2
FRK 4/2A BG
4044211109929
100
5
