3489.4
3489.4
    CONTA-CLIP
    END PLATE
3489.4 数据手册
Data sheet 3489.4 FAPSI 4/2A BK End plate, Width: 1.5 mm, Colour: Black RAL: 9005 Business data Article number 3489.4 Article name FAPSI 4/2A BK GTIN (EAN) 4044211184681 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 2.65 g Weight per piece (including packaging) 2.75 g Unit of weight G Customs number 85389099 Country of origin EU Prio-Article 3489.4 Product description End plate Creation date 16.12.2023 10:04:02 Subject to technical changes 1 Data sheet 3489.4 FAPSI 4/2A BK Technical data Dimensions Length 67.3 mm Width 1.5 mm Height 35.1 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 10:04:02 No Subject to technical changes 2 Data sheet 3489.4 FAPSI 4/2A BK Media Creation date 16.12.2023 10:04:02 Subject to technical changes 3 Data sheet 3489.4 FAPSI 4/2A BK Accessories ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3290.4 FSIK 4/2A BK 4044211180287 25 ST Fuse-disconnect terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3291.4 FSIK 4/2A/LED 12-30V AC/DC BK 4044211188962 25 ST Disconnect-blade terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3239.4 FSIK 4/2A/MT BK 4044211209933 50 ST Fuse-disconnect terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3292.4 FSIK 4/2A/LED 30-60V AC/DC BK 4044211188979 25 ST Fuse-disconnect terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3293.4 FSIK 4/2A/LED 110-250V AC/DC BK 4044211188986 25 ST Creation date 16.12.2023 10:04:02 Subject to technical changes 4
3489.4 价格&库存
很抱歉,暂时无法提供与“3489.4”相匹配的价格&库存,您可以联系我们找货
    • 20+9.3278420+1.20812
