3481.5
3481.5
    CONTA-CLIP
    END PLATE
3481.5 数据手册
Data sheet 3481.5 FAPT 2,5/2A BU End plate, Width: 1.5 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 3481.5 Article name FAPT 2,5/2A BU GTIN (EAN) 4044211137908 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 2.7 g Weight per piece (including packaging) 2.91 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3481.2 Product description End plate Creation date 15.12.2023 22:37:54 Subject to technical changes 1 Data sheet 3481.5 FAPT 2,5/2A BU Technical data Dimensions Length 67.5 mm Width 1.5 mm Height 36.2 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Environmental Product Compliance REACH Candidate Substance Note Creation date 15.12.2023 22:37:54 No Subject to technical changes 2 Data sheet 3481.5 FAPT 2,5/2A BU Media Creation date 15.12.2023 22:37:54 Subject to technical changes 3 Data sheet 3481.5 FAPT 2,5/2A BU Accessories ##INVERSE##CONTA-CONNECT Basic terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated crosssection: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3257.2 FTRK 2,5/2A/OT BG 4044211137687 100 Disconnect-blade terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3259.2 FTRK 2,5/2A/MT BG 4044211137748 100 Fuse-disconnect terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3263.2 FTRK 2,5/2A/ZS BG 4044211137847 100 Disconnect terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3261.2 FTRK 2,5/2A/ST BG 4044211137809 100 Creation date 15.12.2023 22:37:54 Subject to technical changes 4
3481.5 价格&库存
很抱歉,暂时无法提供与“3481.5”相匹配的价格&库存,您可以联系我们找货
