3511.2
3511.2
    CONTA-CLIP
    EARTH TERMINAL
3511.2 数据手册
Data sheet 3511.2 ZSL 2,5/3A GNYE Protective earth terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated crosssection: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow Business data Article number 3511.2 Article name ZSL 2,5/3A GNYE GTIN (EAN) 4044211151737 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 13.4 g Weight per piece (including packaging) 14 g Unit of weight G Customs number 85369010 Country of origin BG Product description Protective earth terminal Colour Green-yellow Creation date 15.12.2023 10:11:51 Subject to technical changes 1 Data sheet 3511.2 ZSL 2,5/3A GNYE Technical data Dimensions Length 71.3 mm Width 5.1 mm Height TS 35/7.5 39 mm Ratings Rated cross-section 2.5 mm² Overvoltage category III Contamination degree 3 Connection data Connection principle Tension-spring connection Connection position Diagonal Connections 3 Number of terminals per level 3 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.5 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.5 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.5 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Wire cross-section AWG, min. 20 Wire cross-section AWG, max. 12 Stripping length 10 mm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A3 End plate required Number of test pick-off options Creation date 15.12.2023 10:11:51 2 Subject to technical changes 2 Data sheet 3511.2 ZSL 2,5/3A GNYE Technical data Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 10:11:51 Subject to technical changes 3 Data sheet 3511.2 ZSL 2,5/3A GNYE Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA wire cross-section AWG, min. 20 CSA wire cross-section AWG, max. 12 CSA stripping length 10 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus wire cross-section AWG, min. 20 CSAus wire cross-section AWG, max. 12 CSAus stripping length 10 mm cUL Recognized cUL approval C22.2 No 158 cUL wire cross-section single-core (rigid) AWG, min. 20 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 20 cUL wire cross-section stranded AWG, max. 12 cUL wire material Cu cUL Recognized 1 KEMA KEUR approval KEMA KEUR approval EN 60947-7-2:2009 KEMA KEUR approval granted yes KEMA wire cross-section single core (rigid), min. 0.5 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.5 mm² KEMA wire cross-section stranded, max. 4 mm² Creation date 15.12.2023 10:11:51 Subject to technical changes 4 Data sheet 3511.2 ZSL 2,5/3A GNYE Approvals UL Recognized UL approval UL 1059 UL wire cross-section single-core (rigid) AWG, min. 20 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 20 UL wire cross-section stranded AWG, max. 12 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 DNV GL Approval DNV GL Certificate number TAE00000YB DNV GL Location Classes Temperature: B, Humidity: B, Vibration: A DNV GL approval granted 1 DNV GL rated cross-section 2.5 mm² DNV GL test standard IEC 60947-7-2:2009 DNV GL wire cross-section single-core (rigid), max. 4 mm² DNV GL wire cross-section stranded, max. 2.5 mm² Creation date 15.12.2023 10:11:51 Subject to technical changes 5 Data sheet 3511.2 ZSL 2,5/3A GNYE Media Creation date 15.12.2023 10:11:51 Subject to technical changes 6 Data sheet 3511.2 ZSL 2,5/3A GNYE Accessories End plate End plate, Width: 2 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3701.2 ZAP 2,5/3A BG 4044211060053 50 Actuating tool Actuating tool, No. of poles: 1, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3808.0 BWMA 1 (0,5 x 3,5 mm) 4044211078850 1 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3748.2 ZES 35 BG 4044211060572 50 Test adapter Test adapter, Pitch size: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3740.2 ZTA 2,5 BG 4044211060497 10 ST Quick marking Creation date 15.12.2023 10:11:51 Subject to technical changes 7 Data sheet 3511.2 ZSL 2,5/3A GNYE Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4600.7 PMC SB 5/50 WH 4044211088903 500 ST Four-way cover Cover, Length: 6.7 mm, Width: 20.4 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3706.0 ZAD 2,5/4/B YE 4044211060244 20 ST Reducing sleeves Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 3751.6 ZRH 2,5/0,25-0,5 GR 4044211060602 1000 ST Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 3750.7 ZRH 2,5/0,13-0,2 WH 4044211060596 1000 ST Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3752.4 ZRH 2,5/0,75-1,0 BK 4044211060619 1000 ST Creation date 15.12.2023 10:11:51 Subject to technical changes 8
3511.2 价格&库存
很抱歉,暂时无法提供与“3511.2”相匹配的价格&库存,您可以联系我们找货
