3517.5
3517.5
    CONTA-CLIP
    FEED-THROUGH TERMINAL
3517.5 数据手册
Data sheet 3517.5 ZRK 4/4A BU Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated crosssection: 4 mm², Width: 6.1 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 3517.5 Article name ZRK 4/4A BU GTIN (EAN) 4044211058654 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 15.2 g Weight per piece (including packaging) 16.4 g Unit of weight G Customs number 85369010 Prio-Article 3517.2 Product description Feed-through terminal Creation date 15.12.2023 03:29:14 Subject to technical changes 1 Data sheet 3517.5 ZRK 4/4A BU Technical data Dimensions Length 93 mm Width 6.1 mm Height TS 35/7.5 42 mm Ratings Rated voltage 800 V Rated current 32 A Rated cross-section 4 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.02 W Connection data Connection principle Tension-spring connection Connection position Diagonal Connections 4 Number of terminals per level 4 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.5 mm² Wire cross-section single core (rigid)/stranded, max. 6 mm² Wire cross-section stranded, min. 0.6 mm² Wire cross-section stranded, max. 6 mm² Wire cross-section stranded with wire-end ferrules, min. 0.5 mm² Wire cross-section stranded with wire-end ferrules, max. 4 mm² Wire cross-section AWG, min. 20 Wire cross-section AWG, max. 10 Stripping length 12 mm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 15.12.2023 03:29:14 Subject to technical changes 2 Data sheet 3517.5 ZRK 4/4A BU Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A4 Number of cross-connection channels 2 End plate required Number of test pick-off options 2 Environmental Product Compliance REACH Candidate Substance Note Creation date 15.12.2023 03:29:14 No Subject to technical changes 3 Data sheet 3517.5 ZRK 4/4A BU Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 600 V CSA Usegroup C: rated current 35 A CSA wire cross-section AWG, min. 20 CSA wire cross-section AWG, max. 10 CSA stripping length 10 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 600 V CSAus Usegroup C: rated current 35 A CSAus wire cross-section AWG, min. 20 CSAus wire cross-section AWG, max. 10 CSAus stripping length 10 mm KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 800 V KEMA rated current 32 A KEMA rated impulse voltage 8 kV KEMA wire cross-section single core (rigid), min. 0.6 mm² KEMA wire cross-section single-core (rigid), max. 6 mm² KEMA wire cross-section stranded, min. 0.6 mm² KEMA wire cross-section stranded, max. 6 mm² Creation date 15.12.2023 03:29:14 Subject to technical changes 4 Data sheet 3517.5 ZRK 4/4A BU Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 600 V UL Usegroup B: rated current 35 A UL Usegroup C: rated voltage 600 V UL Usegroup C: rated current 35 A UL Usegroup D: rated voltage 600 V UL Usegroup D: rated current 35 A UL wire cross-section single-core (rigid) AWG, min. 20 UL wire cross-section single-core (rigid) AWG, max. 10 UL wire cross-section stranded AWG, min. 20 UL wire cross-section stranded AWG, max. 10 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 DNV GL Approval DNV GL Location Classes Temperature: B, Humidity: B, Vibration: A DNV GL approval granted 1 DNV GL rated cross-section 4 mm² DNV GL rated current 32 A DNV GL rated voltage 800 V DNV GL test standard IEC 60947-7-1:2009 DNV GL wire cross-section single-core (rigid), max. 6 mm² DNV GL wire cross-section stranded, max. 4 mm² Creation date 15.12.2023 03:29:14 Subject to technical changes 5 Data sheet 3517.5 ZRK 4/4A BU Media Creation date 15.12.2023 03:29:14 Subject to technical changes 6 Data sheet 3517.5 ZRK 4/4A BU Accessories End plate End plate, Width: 2 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3705.2 ZAP 4/4A BG 4044211060213 50 End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3748.2 ZES 35 BG 4044211060572 50 Insulated cross-connector Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 22.3 mm, Rated cross-section: 4 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3722.8 ZQI 4/4 YE 4044211060404 20 Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 34.5 mm, Rated cross-section: 4 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3724.8 ZQI 4/6 YE 4044211060428 20 Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 10.1 mm, Rated cross-section: 4 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3720.8 ZQI 4/2 YE 4044211060381 50 Creation date 15.12.2023 03:29:14 Subject to technical changes 7 Data sheet 3517.5 ZRK 4/4A BU Insulated cross-connector Insulated cross-connector, No. of poles: 5, Mounting type: Plug in, Width: 28.4 mm, Rated cross-section: 4 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3723.8 ZQI 4/5 YE 4044211060411 20 Insulated cross-connector, No. of poles: 9, Mounting type: Plug in, Width: 52.8 mm, Rated cross-section: 4 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3727.8 ZQI 4/9 YE 4044211060459 10 Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 16.2 mm, Rated cross-section: 4 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3721.8 ZQI 4/3 YE 4044211060398 50 Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 58.9 mm, Rated cross-section: 4 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3728.8 ZQI 4/10 YE 4044211060466 10 Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 40.6 mm, Rated cross-section: 4 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3725.8 ZQI 4/7 YE 4044211060435 20 Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 46.7 mm, Rated cross-section: 4 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3726.8 ZQI 4/8 YE 4044211060442 10 Creation date 15.12.2023 03:29:14 Subject to technical changes 8 Data sheet 3517.5 ZRK 4/4A BU Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4702.7 PMC SB 6/50 WH 4044211089986 500 ST Four-way cover Cover, Length: 8 mm, Width: 24.4 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3707.0 ZAD 4/4/B YE 4044211060251 20 ST Reducing sleeves Reducing sleeve, Width: 61 mm, Pitch size: 6.1 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 3753.7 ZRH 4/0,13-0,2 WH 4044211060626 1000 ST Reducing sleeve, Width: 61 mm, Pitch size: 6.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3755.4 ZRH 4/0,75-1,0 BK 4044211060640 1000 ST Reducing sleeve, Width: 61 mm, Pitch size: 6.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 3754.6 ZRH 4/0,25-0,5 GR 4044211060633 1000 ST Creation date 15.12.2023 03:29:14 Subject to technical changes 9
3517.5 价格&库存
很抱歉,暂时无法提供与“3517.5”相匹配的价格&库存,您可以联系我们找货
  • 100+25.00847100+3.24158
