3518.2
3518.2
    CONTA-CLIP
    FEED-THROUGH TERMINAL
3518.2 数据手册
Data sheet 3518.2 ZRK 4/2x2A BG Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated crosssection: 4 mm², Width: 6.1 mm, Colour: Beige Business data Article number 3518.2 Article name ZRK 4/2x2A BG GTIN (EAN) 4044211058661 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 14.4 g Weight per piece (including packaging) 15.4 g Unit of weight G Customs number 85369010 Country of origin CZ Prio-Article 3518.2 Product description Feed-through terminal Creation date 16.12.2023 00:30:22 Subject to technical changes 1 Data sheet 3518.2 ZRK 4/2x2A BG Technical data Dimensions Length 93 mm Width 6.1 mm Height TS 35/7.5 42 mm Ratings Rated voltage 800 V Rated current 32 A Rated cross-section 4 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.02 W Connection data Connection principle Tension-spring connection Connection position Diagonal Connections 2x2 Number of terminals per level 4 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.5 mm² Wire cross-section single core (rigid)/stranded, max. 6 mm² Wire cross-section stranded, min. 0.6 mm² Wire cross-section stranded, max. 6 mm² Wire cross-section stranded with wire-end ferrules, min. 0.5 mm² Wire cross-section stranded with wire-end ferrules, max. 4 mm² Wire cross-section AWG, min. 20 Wire cross-section AWG, max. 10 Stripping length 12 mm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 16.12.2023 00:30:22 Subject to technical changes 2 Data sheet 3518.2 ZRK 4/2x2A BG Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A4 End plate required Number of test pick-off options 2 Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 00:30:22 No Subject to technical changes 3 Data sheet 3518.2 ZRK 4/2x2A BG Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes Nemko approval EN 60947-7-1:2009 Nemko approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 600 V CSA Usegroup C: rated current 35 A CSA wire cross-section AWG, min. 20 CSA wire cross-section AWG, max. 10 CSA stripping length 10 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 600 V CSAus Usegroup C: rated current 35 A CSAus wire cross-section AWG, min. 20 CSAus wire cross-section AWG, max. 10 CSAus stripping length 10 mm KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 800 V KEMA rated current 32 A KEMA rated impulse voltage 8 kV KEMA wire cross-section single core (rigid), min. 0.6 mm² KEMA wire cross-section single-core (rigid), max. 6 mm² KEMA wire cross-section stranded, min. 0.6 mm² KEMA wire cross-section stranded, max. 6 mm² Creation date 16.12.2023 00:30:22 Subject to technical changes 4 Data sheet 3518.2 ZRK 4/2x2A BG Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 600 V UL Usegroup B: rated current 35 A UL Usegroup C: rated voltage 600 V UL Usegroup C: rated current 35 A UL Usegroup D: rated voltage 600 V UL Usegroup D: rated current 35 A UL wire cross-section single-core (rigid) AWG, min. 20 UL wire cross-section single-core (rigid) AWG, max. 10 UL wire cross-section stranded AWG, min. 20 UL wire cross-section stranded AWG, max. 10 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 00:30:22 Subject to technical changes 5 Data sheet 3518.2 ZRK 4/2x2A BG Media Creation date 16.12.2023 00:30:22 Subject to technical changes 6 Data sheet 3518.2 ZRK 4/2x2A BG Accessories End plate End plate, Width: 2 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3705.2 ZAP 4/4A BG 4044211060213 50 End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3748.2 ZES 35 BG 4044211060572 50 Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4702.7 PMC SB 6/50 WH 4044211089986 500 ST Four-way cover Cover, Length: 8 mm, Width: 24.4 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3707.0 ZAD 4/4/B YE 4044211060251 20 ST Reducing sleeves Creation date 16.12.2023 00:30:22 Subject to technical changes 7 Data sheet 3518.2 ZRK 4/2x2A BG Reducing sleeve, Width: 61 mm, Pitch size: 6.1 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 3753.7 ZRH 4/0,13-0,2 WH 4044211060626 1000 ST Reducing sleeve, Width: 61 mm, Pitch size: 6.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3755.4 ZRH 4/0,75-1,0 BK 4044211060640 1000 ST Reducing sleeve, Width: 61 mm, Pitch size: 6.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 3754.6 ZRH 4/0,25-0,5 GR 4044211060633 1000 ST Creation date 16.12.2023 00:30:22 Subject to technical changes 8
3518.2 价格&库存
很抱歉,暂时无法提供与“3518.2”相匹配的价格&库存,您可以联系我们找货
