Data sheet
3518.5 ZRK 4/2x2A BU
Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated crosssection: 4 mm², Width: 6.1 mm, Colour: Blue
RAL: Ähnlich 5005
Business data
Article number
3518.5
Article name
ZRK 4/2x2A BU
GTIN (EAN)
4044211058685
Packaging unit
100
Quantity unit
PC
Weight per piece (not including packaging)
14.4 g
Weight per piece (including packaging)
15.4 g
Unit of weight
G
Customs number
85369010
Country of origin
CZ
Prio-Article
3518.2
Product description
Creation date 17.12.2023 08:47:00
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
93 mm
Width
6.1 mm
Height TS 35/7.5
42 mm
Ratings
Rated voltage
800 V
Rated current
32 A
Rated cross-section
4 mm²
Rated impulse voltage
8 kV
Overvoltage category
III
Contamination degree
3
Maximum power dissipation for nominal condition
1.02 W
Connection data
Connection principle
Connection position
Diagonal
Connections
2x2
Number of terminals per level
4
Number of levels
1
Wire cross-section single-core (rigid) / stranded, min.
0.5 mm²
Wire cross-section single core (rigid)/stranded, max.
6 mm²
Wire cross-section stranded, min.
0.6 mm²
Wire cross-section stranded, max.
6 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.5 mm²
max.
4 mm²
Wire cross-section AWG, min.
Wire cross-section AWG, max.
10
Stripping length
12 mm
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-0
Working temperature, min.
-40 °C
Working temperature, max.
120 °C
2
Data sheet
Technical data
Further technical data
Mounting type
Mounting rail TS 35/7,5
Gauge plug acc. to EN 60 947-1
A4
End plate required
Number of test pick-off options
2
Environmental Product Compliance
REACH Candidate Substance Note
No
3
Data sheet
Approvals
Standards and regulations
EAC approval
TR ZU 004/2011
EAC approval granted
yes
Nemko approval
EN 60947-7-1:2009
Nemko approval granted
yes
CSA approval
CSA approval
C22.2 No 158
CSA approval granted
yes
CSA Usegroup C: rated voltage
600 V
CSA Usegroup C: rated current
35 A
CSA wire cross-section AWG, min.
CSA wire cross-section AWG, max.
10
CSA stripping length
10 mm
CSAus approval
CSAus approval
UL 1059
CSAus approval granted
yes
CSAus Usegroup C: rated voltage
600 V
CSAus Usegroup C: rated current
35 A
CSAus wire cross-section AWG, min.
CSAus wire cross-section AWG, max.
10
CSAus stripping length
10 mm
KEMA KEUR approval
KEMA KEUR approval
EN 60947-7-1:2009
KEMA KEUR approval granted
yes
KEMA rated voltage
800 V
KEMA rated current
32 A
KEMA rated impulse voltage
8 kV
KEMA wire cross-section single core (rigid), min.
0.6 mm²
KEMA wire cross-section single-core (rigid), max.
6 mm²
KEMA wire cross-section stranded, min.
0.6 mm²
KEMA wire cross-section stranded, max.
6 mm²
4
Data sheet
Approvals
UL Recognized
UL approval
UL 1059
UL Usegroup B: rated voltage
600 V
UL Usegroup B: rated current
35 A
UL Usegroup C: rated voltage
600 V
UL Usegroup C: rated current
35 A
UL Usegroup D: rated voltage
600 V
UL Usegroup D: rated current
35 A
UL wire cross-section single-core (rigid) AWG, min.
UL wire cross-section single-core (rigid) AWG, max.
10
UL wire cross-section stranded AWG, min.
UL wire cross-section stranded AWG, max.
10
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL Recognized
1
5
Data sheet
Media
6
Data sheet
Accessories
End plate
End plate, Width: 2 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3705.2
ZAP 4/4A BG
4044211060213
50
End stop
End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 6 mm, Colour:
Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3748.2
ZES 35 BG
4044211060572
50
Quick marking
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
4702.7
PMC SB 6/50 WH
4044211089986
500 ST
Four-way cover
Cover, Length: 8 mm, Width: 24.4 mm, Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3707.0
ZAD 4/4/B YE
4044211060251
20 ST
Reducing sleeves
7
Data sheet
Reducing sleeve, Width: 61 mm, Pitch size: 6.1 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
3753.7
ZRH 4/0,13-0,2 WH
4044211060626
1000 ST
Reducing sleeve, Width: 61 mm, Pitch size: 6.1 mm, Colour: Black
Article number
Article name
GTIN (EAN)
Packaging
unit
3755.4
ZRH 4/0,75-1,0 BK
4044211060640
1000 ST
Reducing sleeve, Width: 61 mm, Pitch size: 6.1 mm, Colour: Grey
Article number
Article name
GTIN (EAN)
Packaging
unit
3754.6
ZRH 4/0,25-0,5 GR
4044211060633
1000 ST
8
