3531.2
3531.2
    CONTA-CLIP
    板对板连接器
3531.2 数据手册
Data sheet 3531.2 ZIZA 1,5/3/B/LED(RD)/24V BG Initiator terminal / actuator terminal / block variant, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour: Beige Business data Article number 3531.2 Article name ZIZA 1,5/3/B/LED(RD)/24V BG GTIN (EAN) 4044211058760 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 7.08 g Weight per piece (including packaging) 8.48 g Unit of weight G Customs number 85369010 Country of origin BG Product description Initiator terminal / actuator terminal / block variant Colour Beige Creation date 15.12.2023 02:07:47 Subject to technical changes 1 Data sheet 3531.2 ZIZA 1,5/3/B/LED(RD)/24V BG Technical data Dimensions Length 68.7 mm Width 5.1 mm Height TS 35/7.5 40.5 mm Pitch 5 mm Ratings Rated voltage 400 V Rated current 17.5 A Rated cross-section 1.5 mm² Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 0.56 W Connection data Connection principle Tension-spring connection Connections 4 Number of terminals per level 4 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.5 mm² Wire cross-section single core (rigid)/stranded, max. 2.5 mm² Wire cross-section stranded, min. 0.5 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.5 mm² Wire cross-section stranded with wire-end ferrules, max. 1.5 mm² Wire cross-section AWG, min. 26 Wire cross-section AWG, max. 14 Stripping length 8 mm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 15.12.2023 02:07:47 Subject to technical changes 2 Data sheet 3531.2 ZIZA 1,5/3/B/LED(RD)/24V BG Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A1 Number of cross-connection channels 1 End plate required Can be cross-connected Colour of lamp Red Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 02:07:47 Subject to technical changes 3 Data sheet 3531.2 ZIZA 1,5/3/B/LED(RD)/24V BG Approvals CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 300 V CSA Usegroup C: rated current 12,5 A CSA wire cross-section AWG, min. 26 CSA wire cross-section AWG, max. 14 CSA stripping length 8 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 300 V CSAus Usegroup C: rated current 12,5 A CSAus wire cross-section AWG, min. 26 CSAus wire cross-section AWG, max. 14 CSAus stripping length 8 mm cUL Recognized cUL approval C22.2 No 158 cUL Usegroup C: rated voltage 300 V cUL Usegroup C: rated current 12,5 A cUL wire cross-section single-core (rigid) AWG, min. 26 cUL wire cross-section single-core (rigid) AWG, max. 14 cUL wire cross-section stranded AWG, min. 26 cUL wire cross-section stranded AWG, max. 14 cUL wire material Cu cUL Recognized 1 Creation date 15.12.2023 02:07:47 Subject to technical changes 4 Data sheet 3531.2 ZIZA 1,5/3/B/LED(RD)/24V BG Approvals KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 400 V KEMA rated current 17,5 A KEMA rated impulse voltage 4 kV KEMA wire cross-section single core (rigid), min. 0.5 mm² KEMA wire cross-section single-core (rigid), max. 2.5 mm² KEMA wire cross-section stranded, min. 0.5 mm² KEMA wire cross-section stranded, max. 2.5 mm² UL Recognized UL approval UL 1059 UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 12,5 A UL wire cross-section single-core (rigid) AWG, min. 26 UL wire cross-section single-core (rigid) AWG, max. 14 UL wire cross-section stranded AWG, min. 14 UL wire cross-section stranded AWG, max. 26 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 DNV GL Approval DNV GL Certificate number TAE00000Y9 DNV GL Location Classes Temperature: B, Humidity: B, Vibration: A DNV GL approval granted 1 DNV GL rated cross-section 1.5 mm² DNV GL rated current 17,5 A DNV GL rated voltage 400 V DNV GL test standard IEC 60947-7-1:2009 DNV GL wire cross-section single-core (rigid), max. 2.5 mm² DNV GL wire cross-section stranded, max. 1.5 mm² Creation date 15.12.2023 02:07:47 Subject to technical changes 5 Data sheet 3531.2 ZIZA 1,5/3/B/LED(RD)/24V BG Media Creation date 15.12.2023 02:07:47 Subject to technical changes 6 Data sheet 3531.2 ZIZA 1,5/3/B/LED(RD)/24V BG Accessories End plate End plate, Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3746.2 ZAP/TW ZIZA 1,5/3 BG 4044211060558 20 ST Label holder Label holder, Pitch size: 5.1 mm, Colour: beige Article number Article name GTIN (EAN) Packaging unit 3786.2 ZBA 2 BG 4044211061128 50 ST Label holder, Pitch size: 5.1 mm, Colour: beige Article number Article name GTIN (EAN) Packaging unit 3787.2 ZBA 2/Z BG 4044211061135 50 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3748.2 ZES 35 BG 4044211060572 50 Potential distribution strip Potential distribution strip, Tension-spring connection, Mounting type: Plug in, Rated cross-section: 1.5 mm², Width: 8.7 mm, Colour: Red-brown Article number Article name GTIN (EAN) Packaging unit 3739.6 ZPL 1,5 RB 4044211060480 100 Creation date 15.12.2023 02:07:47 Subject to technical changes 7 Data sheet 3531.2 ZIZA 1,5/3/B/LED(RD)/24V BG Potential distribution strip Potential distribution strip, Tension-spring connection, Mounting type: Plug in, Rated cross-section: 1.5 mm², Width: 8.7 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3743.2 ZPL 1,5/PE GNYE 4044211060527 100 ST Potential distribution strip, Tension-spring connection, Mounting type: Plug in, Rated cross-section: 1.5 mm², Width: 8.7 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3791.8 ZPL 1,5 YE 4044211061197 100 ST Potential distribution strip, Tension-spring connection, Mounting type: Plug in, Rated cross-section: 1.5 mm², Width: 8.7 mm, Colour: Green Article number Article name GTIN (EAN) Packaging unit 3792.1 ZPL 1,5 GN 4044211061203 100 ST Potential distribution strip, Tension-spring connection, Mounting type: Plug in, Rated cross-section: 1.5 mm², Width: 8.7 mm, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 3793.3 ZPL 1,5 OG 4044211061210 100 ST Potential distribution strip, Tension-spring connection, Mounting type: Plug in, Rated cross-section: 1.5 mm², Width: 8.7 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3738.2 ZPL 1,5 BG 4044211060473 100 ST Insulated cross-connector Creation date 15.12.2023 02:07:47 Subject to technical changes 8 Data sheet 3531.2 ZIZA 1,5/3/B/LED(RD)/24V BG Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 9.1 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3710.8 ZQI 2,5/2 YE 4044211060282 50 Insulated cross-connector, No. of poles: 99, Mounting type: Plug in, Width: 500 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3719.8 ZQI 2,5/0,5 m/99 Pole YE 4044211060374 2 Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4600.7 PMC SB 5/50 WH 4044211088903 500 ST Creation date 15.12.2023 02:07:47 Subject to technical changes 9 Data sheet 3531.2 ZIZA 1,5/3/B/LED(RD)/24V BG Reducing sleeves Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 3751.6 ZRH 2,5/0,25-0,5 GR 4044211060602 1000 ST Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 3750.7 ZRH 2,5/0,13-0,2 WH 4044211060596 1000 ST Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3752.4 ZRH 2,5/0,75-1,0 BK 4044211060619 1000 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1085.0 SDB 0,5x3,0 4044211014643 1 ST Creation date 15.12.2023 02:07:47 Subject to technical changes 10
3531.2 价格&库存
很抱歉,暂时无法提供与“3531.2”相匹配的价格&库存,您可以联系我们找货
  • 50+65.9842650+8.27456
