Data sheet
3573.2 ZRKD 2,5/D4 BG
Double-level terminal with electronic components, Tension-spring connection, Mounting type: Mounting rail
TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige
Business data
Article number
3573.2
Article name
ZRKD 2,5/D4 BG
GTIN (EAN)
4044211059170
Packaging unit
100
Quantity unit
PC
Weight per piece (not including packaging)
12.4 g
Weight per piece (including packaging)
13.2 g
Unit of weight
G
Customs number
85369010
Country of origin
BG
Prio-Article
3573.2
Product description
Double-level terminals with electronic components
Creation date 14.12.2023 18:48:16
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
83.6 mm
Width
5.1 mm
Height TS 35/7.5
53 mm
Height TS 35 / 7.5 with BA
64 mm
Ratings
Rated voltage
500 V
Rated current
1A
Rated cross-section
2.5 mm²
Rated impulse voltage
6 kV
Overvoltage category
III
Contamination degree
3
Connection data
Connection principle
Connection position
Diagonal
Connections
2x2
Number of terminals per level
2
Wire cross-section single-core (rigid) / stranded, min.
0.5 mm²
Wire cross-section single core (rigid)/stranded, max.
4 mm²
Wire cross-section stranded, min.
0.5 mm²
Wire cross-section stranded, max.
4 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.5 mm²
max.
2.5 mm²
Wire cross-section AWG, min.
Wire cross-section AWG, max.
12
Stripping length
10 mm
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-0
Working temperature, min.
-40 °C
Working temperature, max.
120 °C
2
Data sheet
Technical data
Further technical data
Mounting type
Mounting rail TS 35/7,5
Gauge plug acc. to EN 60 947-1
A3
Number of cross-connection channels
1
Diode
1N4007 / 1000V / 1A
Environmental Product Compliance
REACH Candidate Substance Note
No
3
Data sheet
Approvals
Standards and regulations
EAC approval
TR ZU 004/2011
EAC approval granted
yes
CSA approval
CSA approval
C22.2 No 158
CSA approval granted
yes
CSA Usegroup C: rated voltage
300 V
CSA Usegroup C: rated current
1A
CSA wire cross-section AWG, min.
CSA wire cross-section AWG, max.
12
CSA stripping length
10 mm
CSAus approval
CSAus approval
UL 1059
CSAus approval granted
yes
CSAus Usegroup C: rated voltage
300 V
CSAus Usegroup C: rated current
1A
CSAus wire cross-section AWG, min.
CSAus wire cross-section AWG, max.
12
CSAus stripping length
10 mm
KEMA KEUR approval
KEMA KEUR approval
EN 60947-7-1:2009
KEMA KEUR approval granted
yes
KEMA rated voltage
500 V
KEMA rated current
1A
KEMA rated impulse voltage
6 kV
KEMA wire cross-section single core (rigid), min.
0.5 mm²
KEMA wire cross-section single-core (rigid), max.
4 mm²
KEMA wire cross-section stranded, min.
0.5 mm²
KEMA wire cross-section stranded, max.
4 mm²
4
Data sheet
Approvals
UL Recognized
UL approval
UL 1059
UL Usegroup B: rated voltage
300 V
UL Usegroup B: rated current
1A
UL Usegroup C: rated voltage
300 V
UL Usegroup C: rated current
1A
UL Usegroup D: rated voltage
300 V
UL Usegroup D: rated current
1A
UL wire cross-section single-core (rigid) AWG, min.
UL wire cross-section single-core (rigid) AWG, max.
12
UL wire cross-section stranded AWG, min.
UL wire cross-section stranded AWG, max.
12
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL Recognized
1
5
Data sheet
Media
6
Data sheet
Accessories
End plate
End plate, Width: 2 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3756.2
ZAPD 2,5 BG
4044211060664
Identification adapter
Label holder, Pitch size: 5.1 mm, Colour: beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3745.2
ZBA 1 BG
4044211060541
20 ST
End stop
End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 6 mm, Colour:
Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3748.2
ZES 35 BG
4044211060572
50
Test adapter
Test adapter, Pitch size: 5.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3740.2
ZTA 2,5 BG
4044211060497
10 ST
Insulated cross-connector
7
Data sheet
Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 34.6 mm,Rated
cross-section: 2.5 mm², Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3715.8
ZQI 2,5/7 YE
4044211060336
Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 9.1 mm, Rated
Article number
Article name
GTIN (EAN)
Packaging
unit
3710.8
ZQI 2,5/2 YE
4044211060282
50
Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 49.9 mm,
Rated cross-section: 2.5 mm², Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3718.8
ZQI 2,5/10 YE
4044211060367
10
Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 14.2 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3711.8
ZQI 2,5/3 YE
4044211060299
50
Insulated cross-connector, No. of poles: 5, Mounting type: Plug in, Width: 24.4 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3713.8
ZQI 2,5/5 YE
4044211060312
Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 39.7 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3716.8
ZQI 2,5/8 YE
4044211060343
10
8
Data sheet
Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 19.3 mm,Rated
Article number
Article name
GTIN (EAN)
Packaging
unit
3712.8
ZQI 2,5/4 YE
4044211060305
Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 29.5 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3714.8
ZQI 2,5/6 YE
4044211060329
Insulated cross-connector, No. of poles: 99, Mounting type: Plug in, Width: 500 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3719.8
ZQI 2,5/0,5 m/99 Pole YE
4044211060374
2
Quick marking
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
4600.7
PMC SB 5/50 WH
4044211088903
500 ST
Four-way cover
Cover, Length: 6.7 mm, Width: 20.4 mm, Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3706.0
ZAD 2,5/4/B YE
4044211060244
20 ST
Reducing sleeves
9
Data sheet
Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: Grey
Article number
Article name
GTIN (EAN)
Packaging
unit
3751.6
ZRH 2,5/0,25-0,5 GR
4044211060602
1000 ST
Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
3750.7
ZRH 2,5/0,13-0,2 WH
4044211060596
1000 ST
Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: Black
Article number
Article name
GTIN (EAN)
Packaging
unit
3752.4
ZRH 2,5/0,75-1,0 BK
4044211060619
1000 ST
10
