3574.2
3574.2
    CONTA-CLIP
    DOUBLE-LEVEL TERMINAL WITH ELECT
3574.2 数据手册
Data sheet 3574.2 ZRKD 2,5/D5 BG Double-level terminal with electronic components, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Business data Article number 3574.2 Article name ZRKD 2,5/D5 BG GTIN (EAN) 4044211059187 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 12.4 g Weight per piece (including packaging) 13.2 g Unit of weight G Customs number 85369010 Country of origin BG Product description Double-level terminals with electronic components Colour Beige Creation date 14.12.2023 18:48:23 Subject to technical changes 1 Data sheet 3574.2 ZRKD 2,5/D5 BG Technical data Dimensions Length 83.6 mm Width 5.1 mm Height TS 35/7.5 53 mm Height TS 35 / 7.5 with BA 64 mm Ratings Rated voltage 500 V Rated current 1A Rated cross-section 2.5 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Tension-spring connection Connection position Diagonal Connections 2x2 Number of terminals per level 2 Wire cross-section single-core (rigid) / stranded, min. 0.5 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.5 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.5 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Wire cross-section AWG, min. 20 Wire cross-section AWG, max. 12 Stripping length 10 mm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 14.12.2023 18:48:23 Subject to technical changes 2 Data sheet 3574.2 ZRKD 2,5/D5 BG Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A3 Number of cross-connection channels 1 Diode 1N4007 / 1000V / 1A Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 14.12.2023 18:48:23 Subject to technical changes 3 Data sheet 3574.2 ZRKD 2,5/D5 BG Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 300 V CSA Usegroup C: rated current 1A CSA wire cross-section AWG, min. 20 CSA wire cross-section AWG, max. 12 CSA stripping length 10 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 300 V CSAus Usegroup C: rated current 1A CSAus wire cross-section AWG, min. 20 CSAus wire cross-section AWG, max. 12 CSAus stripping length 10 mm KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 500 V KEMA rated current 1A KEMA rated impulse voltage 6 kV KEMA wire cross-section single core (rigid), min. 0.5 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.5 mm² KEMA wire cross-section stranded, max. 4 mm² Creation date 14.12.2023 18:48:23 Subject to technical changes 4 Data sheet 3574.2 ZRKD 2,5/D5 BG Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 1A UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 1A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 1A UL wire cross-section single-core (rigid) AWG, min. 20 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 20 UL wire cross-section stranded AWG, max. 12 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 14.12.2023 18:48:23 Subject to technical changes 5 Data sheet 3574.2 ZRKD 2,5/D5 BG Media Creation date 14.12.2023 18:48:23 Subject to technical changes 6 Data sheet 3574.2 ZRKD 2,5/D5 BG Accessories End plate End plate, Width: 2 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3756.2 ZAPD 2,5 BG 4044211060664 20 Identification adapter Label holder, Pitch size: 5.1 mm, Colour: beige Article number Article name GTIN (EAN) Packaging unit 3745.2 ZBA 1 BG 4044211060541 20 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3748.2 ZES 35 BG 4044211060572 50 Test adapter Test adapter, Pitch size: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3740.2 ZTA 2,5 BG 4044211060497 10 ST Insulated cross-connector Creation date 14.12.2023 18:48:23 Subject to technical changes 7 Data sheet 3574.2 ZRKD 2,5/D5 BG Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 34.6 mm,Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3715.8 ZQI 2,5/7 YE 4044211060336 20 Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 9.1 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3710.8 ZQI 2,5/2 YE 4044211060282 50 Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 49.9 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3718.8 ZQI 2,5/10 YE 4044211060367 10 Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 14.2 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3711.8 ZQI 2,5/3 YE 4044211060299 50 Insulated cross-connector, No. of poles: 5, Mounting type: Plug in, Width: 24.4 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3713.8 ZQI 2,5/5 YE 4044211060312 20 Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 39.7 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3716.8 ZQI 2,5/8 YE 4044211060343 10 Creation date 14.12.2023 18:48:23 Subject to technical changes 8 Data sheet 3574.2 ZRKD 2,5/D5 BG Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 19.3 mm,Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3712.8 ZQI 2,5/4 YE 4044211060305 20 Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 29.5 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3714.8 ZQI 2,5/6 YE 4044211060329 20 Insulated cross-connector, No. of poles: 99, Mounting type: Plug in, Width: 500 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3719.8 ZQI 2,5/0,5 m/99 Pole YE 4044211060374 2 Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4600.7 PMC SB 5/50 WH 4044211088903 500 ST Four-way cover Cover, Length: 6.7 mm, Width: 20.4 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3706.0 ZAD 2,5/4/B YE 4044211060244 20 ST Reducing sleeves Creation date 14.12.2023 18:48:23 Subject to technical changes 9 Data sheet 3574.2 ZRKD 2,5/D5 BG Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 3751.6 ZRH 2,5/0,25-0,5 GR 4044211060602 1000 ST Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 3750.7 ZRH 2,5/0,13-0,2 WH 4044211060596 1000 ST Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3752.4 ZRH 2,5/0,75-1,0 BK 4044211060619 1000 ST Creation date 14.12.2023 18:48:23 Subject to technical changes 10
3574.2 价格&库存
很抱歉,暂时无法提供与“3574.2”相匹配的价格&库存,您可以联系我们找货
