Data sheet
3581.5 ZRK 6/2A BU
Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated crosssection: 6 mm², Width: 8.1 mm, Colour: Blue
RAL: Ähnlich 5005
Business data
Article number
3581.5
Article name
ZRK 6/2A BU
GTIN (EAN)
4044211059293
Packaging unit
100
Quantity unit
PC
Weight per piece (not including packaging)
16.8 g
Weight per piece (including packaging)
17.8 g
Unit of weight
G
Customs number
85369010
Country of origin
CZ
Prio-Article
3581.2
Product description
Creation date 16.12.2023 00:27:29
Subject to technical changes
1
Data sheet
3581.5 ZRK 6/2A BU
Technical data
Dimensions
Length
65 mm
Width
8.1 mm
Height TS 35/7.5
47.5 mm
Ratings
Rated voltage
1000 V
Rated current
41 A
Rated cross-section
6 mm²
Rated impulse voltage
8 kV
Overvoltage category
III
Contamination degree
3
Maximum power dissipation for nominal condition
1.31 W
Connection data
Connection principle
Connection position
Diagonal
Connections
2
Number of terminals per level
2
Number of levels
1
Wire cross-section single-core (rigid) / stranded, min.
0.5 mm²
Wire cross-section single core (rigid)/stranded, max.
10 mm²
Wire cross-section stranded, min.
0.5 mm²
Wire cross-section stranded, max.
10 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.5 mm²
max.
6 mm²
Wire cross-section AWG, min.
22
Wire cross-section AWG, max.
8
Stripping length
13 mm
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-0
Working temperature, min.
-40 °C
Working temperature, max.
120 °C
2
Data sheet
3581.5 ZRK 6/2A BU
Technical data
Further technical data
Mounting type
Mounting rail TS 35/7,5
Gauge plug acc. to EN 60 947-1
A5
Number of cross-connection channels
1
End plate required
Number of test pick-off options
2
Environmental Product Compliance
REACH Candidate Substance Note
No
3
Data sheet
3581.5 ZRK 6/2A BU
Approvals
Standards and regulations
EAC approval
TR ZU 004/2011
EAC approval granted
yes
CSA approval
CSA approval
C22.2 No 158
CSA approval granted
yes
CSA Usegroup C: rated voltage
600 V
CSA Usegroup C: rated current
50 A
CSA wire cross-section AWG, min.
22
CSA wire cross-section AWG, max.
8
CSA stripping length
10 mm
CSAus approval
CSAus approval
UL 1059
CSAus approval granted
yes
CSAus Usegroup C: rated voltage
600 V
CSAus Usegroup C: rated current
50 A
CSAus wire cross-section AWG, min.
22
CSAus wire cross-section AWG, max.
8
CSAus stripping length
10 mm
cUL Recognized
cUL approval
C22.2 No 158
cUL Usegroup B: rated voltage
600 V
cUL Usegroup B: rated current
50 A
cUL Usegroup C: rated voltage
600 V
cUL Usegroup C: rated current
50 A
cUL Usegroup D: rated voltage
600 V
cUL Usegroup D: rated current
50 A
cUL wire cross-section single-core (rigid) AWG, min.
22
cUL wire cross-section single-core (rigid) AWG, max. 8
cUL wire cross-section stranded AWG, min.
22
cUL wire cross-section stranded AWG, max.
8
cUL wire material
Cu
cUL Recognized
1
4
Data sheet
3581.5 ZRK 6/2A BU
Approvals
KEMA KEUR approval
KEMA KEUR approval
EN 60947-7-1:2009
KEMA KEUR approval granted
yes
KEMA rated voltage
1000 V
KEMA rated current
41 A
KEMA rated impulse voltage
8 kV
KEMA wire cross-section single core (rigid), min.
0.5 mm²
KEMA wire cross-section single-core (rigid), max.
10 mm²
KEMA wire cross-section stranded, min.
0.5 mm²
KEMA wire cross-section stranded, max.
10 mm²
UL Recognized
UL approval
UL 1059
600 V
50 A
600 V
50 A
600 V
50 A
22
8
22
8
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL Recognized
1
5
Data sheet
3581.5 ZRK 6/2A BU
Approvals
DNV GL Approval
DNV GL Location Classes
Temperature: B, Humidity: B, Vibration: A
DNV GL approval granted
1
DNV GL rated cross-section
6 mm²
DNV GL rated current
41 A
DNV GL rated voltage
800 V
DNV GL test standard
IEC 60947-7-1:2009
DNV GL wire cross-section single-core (rigid), max.
10 mm²
DNV GL wire cross-section stranded, max.
6 mm²
6
Data sheet
3581.5 ZRK 6/2A BU
Media
7
Data sheet
3581.5 ZRK 6/2A BU
Accessories
End plate
End plate, Width: 2 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3760.2
ZAP 6/2A BG
4044211060817
End stop
End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 6 mm, Colour:
Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3748.2
ZES 35 BG
4044211060572
50
Insulated cross-connector
Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 15.7 mm,
Rated cross-section: 6 mm², Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3763.8
ZQI 6/2 YE
4044211060893
50
Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 64.3 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3769.8
ZQI 6/8 YE
4044211060954
10 ST
Insulated cross-connector, No. of poles: 9, Mounting type: Plug in, Width: 72.4 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3770.8
ZQI 6/9 YE
4044211060961
10 ST
8
Data sheet
3581.5 ZRK 6/2A BU
Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 23.8 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3764.8
ZQI 6/3 YE
4044211060909
50
Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 31.9 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3765.8
ZQI 6/4 YE
4044211060916
20 ST
Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 56.2 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3768.8
ZQI 6/7 YE
4044211060947
20 ST
Insulated cross-connector, No. of poles: 5, Mounting type: Plug in, Width: 31.9 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3766.8
ZQI 6/5 YE
4044211060923
20 ST
Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 48.1 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3767.8
ZQI 6/6 YE
4044211060930
20 ST
Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 80.5 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3771.8
ZQI 6/10 YE
4044211060978
10 ST
9
Data sheet
3581.5 ZRK 6/2A BU
Quick marking
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
9323.7
PMC SB 8/40 WH
4044211129231
400 ST
Four-way cover
Cover, Length: 10.5 mm, Width: 32.4 mm, Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3708.0
ZAD 6/4/B YE
4044211060268
20 ST
10
