3587.5
3587.5
    CONTA-CLIP
    板对板连接器
3587.5 数据手册
Data sheet 3587.5 ZSRK 2,5/2A-RC BU Feed-through terminal for direct mount, Tension-spring connection, Mounting type: Mounting surface, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 3587.5 Article name ZSRK 2,5/2A-RC BU GTIN (EAN) 4044211059415 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 5g Weight per piece (including packaging) 5.4 g Unit of weight G Customs number 85369010 Prio-Article 3587.2 Product description Feed-through terminal for direct mount Creation date 16.12.2023 15:32:35 Subject to technical changes 1 Data sheet 3587.5 ZSRK 2,5/2A-RC BU Technical data Dimensions Length 40 mm Width 5.1 mm Height 24 mm Ratings Rated voltage 800 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 0.77 W Connection data Connection principle Tension-spring connection Connection position Diagonal Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.5 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.5 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.5 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Wire cross-section AWG, min. 20 Wire cross-section AWG, max. 12 Stripping length 10 mm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 16.12.2023 15:32:35 Subject to technical changes 2 Data sheet 3587.5 ZSRK 2,5/2A-RC BU Technical data Further technical data Mounting type Mounting face Gauge plug acc. to EN 60 947-1 A3 Number of cross-connection channels 1 End plate required Number of test pick-off options 2 Sheet thickness maximum 1 mm Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 15:32:35 No Subject to technical changes 3 Data sheet 3587.5 ZSRK 2,5/2A-RC BU Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 300 V CSA Usegroup C: rated current 20 A CSA wire cross-section AWG, min. 20 CSA wire cross-section AWG, max. 12 CSA stripping length 10 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 300 V CSAus Usegroup C: rated current 20 A CSAus wire cross-section AWG, min. 20 CSAus wire cross-section AWG, max. 12 CSAus stripping length 10 mm cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 20 A cUL Usegroup C: rated voltage 300 V cUL Usegroup C: rated current 20 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 20 A cUL wire cross-section single-core (rigid) AWG, min. 20 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 20 cUL wire cross-section stranded AWG, max. 12 cUL wire material Cu cUL Recognized 1 Creation date 16.12.2023 15:32:35 Subject to technical changes 4 Data sheet 3587.5 ZSRK 2,5/2A-RC BU Approvals German Lloyd approval GL wire cross-section single core (rigid), min. 8 mm² GL wire cross-section, min. 4 mm² DNV GL Location Classes 4 DNV GL approval granted 1 DNV GL rated current 24 A DNV GL rated voltage 800 V DNV GL test standard IEC 60947-7-1:2009 DNV GL wire cross-section single-core (rigid), max. 2.5 mm² DNV GL wire cross-section stranded, max. 2.5 mm² KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 800 V KEMA wire cross-section single core (rigid), min. 0.5 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.5 mm² KEMA wire cross-section stranded, max. 4 mm² UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 20 A UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 20 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 20 A UL wire cross-section single-core (rigid) AWG, min. 20 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 20 UL wire cross-section stranded AWG, max. 12 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 15:32:35 Subject to technical changes 5 Data sheet 3587.5 ZSRK 2,5/2A-RC BU Media Creation date 16.12.2023 15:32:35 Subject to technical changes 6 Data sheet 3587.5 ZSRK 2,5/2A-RC BU Accessories End plate End plate, Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3758.2 ZAP SR/RC BG 4044211060749 50 Actuating tool Actuating tool, No. of poles: 1, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3808.0 BWMA 1 (0,5 x 3,5 mm) 4044211078850 1 ST Test adapter Test adapter, Pitch size: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3740.2 ZTA 2,5 BG 4044211060497 10 ST Insulated cross-connector Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 34.6 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3715.8 ZQI 2,5/7 YE 4044211060336 20 Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 9.1 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3710.8 ZQI 2,5/2 YE 4044211060282 50 Creation date 16.12.2023 15:32:35 Subject to technical changes 7 Data sheet 3587.5 ZSRK 2,5/2A-RC BU Insulated cross-connector Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 49.9 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3718.8 ZQI 2,5/10 YE 4044211060367 10 Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 14.2 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3711.8 ZQI 2,5/3 YE 4044211060299 50 Insulated cross-connector, No. of poles: 5, Mounting type: Plug in, Width: 24.4 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3713.8 ZQI 2,5/5 YE 4044211060312 20 Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 39.7 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3716.8 ZQI 2,5/8 YE 4044211060343 10 Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 19.3 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3712.8 ZQI 2,5/4 YE 4044211060305 20 Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 29.5 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3714.8 ZQI 2,5/6 YE 4044211060329 20 Creation date 16.12.2023 15:32:35 Subject to technical changes 8 Data sheet 3587.5 ZSRK 2,5/2A-RC BU Insulated cross-connector Insulated cross-connector, No. of poles: 99, Mounting type: Plug in, Width: 500 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3719.8 ZQI 2,5/0,5 m/99 Pole YE 4044211060374 2 Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4600.7 PMC SB 5/50 WH 4044211088903 500 ST Four-way cover Cover, Length: 6.7 mm, Width: 20.4 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3706.0 ZAD 2,5/4/B YE 4044211060244 20 ST Reducing sleeves Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 3751.6 ZRH 2,5/0,25-0,5 GR 4044211060602 1000 ST Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 3750.7 ZRH 2,5/0,13-0,2 WH 4044211060596 1000 ST Creation date 16.12.2023 15:32:35 Subject to technical changes 9 Data sheet 3587.5 ZSRK 2,5/2A-RC BU Reducing sleeves Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3752.4 ZRH 2,5/0,75-1,0 BK 4044211060619 1000 ST Creation date 16.12.2023 15:32:35 Subject to technical changes 10
3587.5 价格&库存
很抱歉,暂时无法提供与“3587.5”相匹配的价格&库存,您可以联系我们找货
  • 100+14.39986100+1.86504
