Data sheet
3593.2 ZIKD 2,5/SV/PE GNYE
Three-level initiator terminal | Multi-wire terminal, Tension-spring connection, Mounting type: Mounting rail TS
35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow
Business data
Article number
3593.2
Article name
ZIKD 2,5/SV/PE GNYE
GTIN (EAN)
4044211059521
Packaging unit
50
Quantity unit
PC
Weight per piece (not including packaging)
28.8 g
Weight per piece (including packaging)
30.4 g
Unit of weight
G
Customs number
85369010
Country of origin
BG
Product description
Colour
Green-yellow
Creation date 16.12.2023 02:45:37
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
116.2 mm
Width
5.1 mm
Height TS 35/7.5
68 mm
Ratings
Rated cross-section
2.5 mm²
Overvoltage category
III
Contamination degree
3
Connection data
Connection principle
Connection position
Top
Connections
6
Number of terminals per level
2
Number of levels
3
Levels internally bridged
Wire cross-section single-core (rigid) / stranded, min.
0.5 mm²
Wire cross-section single core (rigid)/stranded, max.
4 mm²
Wire cross-section stranded, min.
0.5 mm²
Wire cross-section stranded, max.
4 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.5 mm²
max.
2.5 mm²
Wire cross-section AWG, min.
Wire cross-section AWG, max.
12
Stripping length
10 mm
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-0
Working temperature, min.
-40 °C
Working temperature, max.
120 °C
2
Data sheet
Technical data
Further technical data
Mounting type
Mounting rail TS 35/7,5
Gauge plug acc. to EN 60 947-1
A3
End plate required
Number of test pick-off options
6
PE connection available
Environmental Product Compliance
REACH Conform
yes
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
RoHS Conform
yes
3
Data sheet
Approvals
Standards and regulations
EAC approval
TR ZU 004/2011
EAC approval granted
yes
CSA approval
CSA approval
C22.2 No 158
CSA approval granted
yes
CSA wire cross-section AWG, min.
CSA wire cross-section AWG, max.
12
CSA stripping length
10 mm
CSAus approval
CSAus approval
UL 1059
CSAus approval granted
yes
CSAus wire cross-section AWG, min.
CSAus wire cross-section AWG, max.
12
CSAus stripping length
10 mm
cUL Recognized
cUL approval
C22.2 No 158
cUL wire cross-section single-core (rigid) AWG, min.
cUL wire cross-section single-core (rigid) AWG, max. 12
cUL wire cross-section stranded AWG, min.
cUL wire cross-section stranded AWG, max.
12
cUL wire material
Cu
cUL Recognized
1
KEMA KEUR approval
KEMA KEUR approval
EN 60947-7-1:2009, EN 60947-7-2:2009
KEMA KEUR approval granted
yes
KEMA wire cross-section single core (rigid), min.
0.5 mm²
KEMA wire cross-section single-core (rigid), max.
4 mm²
KEMA wire cross-section stranded, min.
0.5 mm²
KEMA wire cross-section stranded, max.
4 mm²
4
Data sheet
Approvals
UL Recognized
UL approval
UL 1059
12
12
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL Recognized
1
DNV GL Approval
DNV GL Certificate number
TAE00000Y7
DNV GL Location Classes
Temperature: B, Humidity: B, Vibration: A
DNV GL approval granted
1
DNV GL rated cross-section
2.5 mm²
DNV GL rated current
24 A
DNV GL rated voltage
500 V
DNV GL test standard
IEC 60947-7-1:2009, IEC 60947-7-2:2009
DNV GL wire cross-section single-core (rigid), max.
4 mm²
DNV GL wire cross-section stranded, max.
2.5 mm²
5
Data sheet
Media
6
Data sheet
Accessories
End plate
End plate, Width: 1.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3761.2
ZAP 2,5/ID BG
4044211060855
Actuating tool
Actuating tool, No. of poles: 1, Colour: Black
Article number
Article name
GTIN (EAN)
Packaging
unit
3808.0
BWMA 1 (0,5 x 3,5 mm)
4044211078850
1 ST
Identification adapter
Label holder, Pitch size: 5.1 mm, Colour: beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3813.2
ZBA 3 BG
4044211080747
50 ST
End stop
End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 6 mm, Colour:
Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3748.2
ZES 35 BG
4044211060572
50
Test adapter
7
Data sheet
Test adapter, Pitch size: 5.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3740.2
ZTA 2,5 BG
4044211060497
10 ST
Quick marking
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
4600.7
PMC SB 5/50 WH
4044211088903
500 ST
Four-way cover
Cover, Length: 6.7 mm, Width: 20.4 mm, Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3706.0
ZAD 2,5/4/B YE
4044211060244
20 ST
8
Data sheet
Reducing sleeves
Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: Grey
Article number
Article name
GTIN (EAN)
Packaging
unit
3751.6
ZRH 2,5/0,25-0,5 GR
4044211060602
1000 ST
Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
3750.7
ZRH 2,5/0,13-0,2 WH
4044211060596
1000 ST
Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: Black
Article number
Article name
GTIN (EAN)
Packaging
unit
3752.4
ZRH 2,5/0,75-1,0 BK
4044211060619
1000 ST
9
