3616.5
3616.5
    CONTA-CLIP
    FUSE DISCONNECT TERMINAL WITH FU
3616.5 数据手册
Data sheet 3616.5 ZTRK 2,5/2A/ZS BU Fuse-disconnect terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated crosssection: 2.5 mm², Width: 5.1 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 3616.5 Article name ZTRK 2,5/2A/ZS BU GTIN (EAN) 4044211126612 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 15 g Weight per piece (including packaging) 16 g Unit of weight G Customs number 85369010 Country of origin DE Prio-Article 3616.2 Product description Fuse-disconnect terminal Creation date 17.12.2023 08:49:01 Subject to technical changes 1 Data sheet 3616.5 ZTRK 2,5/2A/ZS BU Technical data Dimensions Length 68 mm Width 5.1 mm Height TS 35/7.5 78.7 mm Ratings Rated voltage (determined by the illuminated display and fuse being used) 400 V Rated current (as fuse-disconnect terminal) 18 A Rated cross-section 2.5 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Tension-spring connection Connection position Diagonal Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.5 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.5 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.5 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Wire cross-section AWG, min. 12 Wire cross-section AWG, max. 20 Stripping length 10 mm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 17.12.2023 08:49:01 Subject to technical changes 2 Data sheet 3616.5 ZTRK 2,5/2A/ZS BU Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Fuse size 5 x 20 mm Gauge plug acc. to EN 60 947-1 A3 Number of cross-connection channels 1 End plate required Number of test pick-off options 2 Power loss in singular arrangement - overload and short-circuit protection, max. 2,5 / 6,3 W / A Power loss in compound arrangement - overload and short-circuit protection, max. 1,6 / 6,3 W / A Power loss in singular arrangement - only short-circuit protection, max. 4 / 6,3 W / A Power loss in compound arrangement - only short-circuit protection, max. 2,5 / 6,3 W / A Version of fuse holder Pluggable Version of fuse cartridge G fuse 5 x 20 Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 08:49:01 No Subject to technical changes 3 Data sheet 3616.5 ZTRK 2,5/2A/ZS BU Approvals CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup B: rated voltage 300 V CSA Usegroup B: rated current 10 A CSA Usegroup C: rated voltage 300 V CSA Usegroup C: rated current 10 A CSA wire cross-section AWG, min. 20 CSA wire cross-section AWG, max. 12 CSA stripping length 10 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup B: rated voltage 300 V CSAus Usegroup B: rated current 10 A CSAus Usegroup C: rated voltage 300 V CSAus Usegroup C: rated current 10 A CSAus wire cross-section AWG, min. 20 CSAus wire cross-section AWG, max. 12 CSAus stripping length 10 mm Creation date 17.12.2023 08:49:01 Subject to technical changes 4 Data sheet 3616.5 ZTRK 2,5/2A/ZS BU Approvals KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009, EN 60947-73:2009 KEMA KEUR approval granted yes KEMA rated voltage 400 V KEMA rated current 6,3 A KEMA rated impulse voltage (fuse holder withoutelectrical components) 6 (4) kV KEMA wire cross-section single core (rigid), min. 0.5 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.5 mm² KEMA wire cross-section stranded, max. 4 mm² KEMA power loss in singular arrangement - overloadand short-circuit protection, max. 2,5 / 6,3 W / A KEMA power loss in compound arrangement -overload and short-circuit protection, max. 1,6 / 6,3 W / A KEMA power loss in singular arrangement - only short-circuit protection, max. 4 / 6,3 W / A KEMA power loss in compound arrangement - only short-circuit protection, max. 2,5 / 6,3 W / A Creation date 17.12.2023 08:49:01 Subject to technical changes 5 Data sheet 3616.5 ZTRK 2,5/2A/ZS BU Media Creation date 17.12.2023 08:49:01 Subject to technical changes 6 Data sheet 3616.5 ZTRK 2,5/2A/ZS BU Accessories End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3796.2 ZAPT 2,5/2A BG 4044211061302 20 End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3748.2 ZES 35 BG 4044211060572 50 Test adapter Test adapter, Pitch size: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3740.2 ZTA 2,5 BG 4044211060497 10 ST Insulated cross-connector Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 34.6 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3715.8 ZQI 2,5/7 YE 4044211060336 20 Creation date 17.12.2023 08:49:01 Subject to technical changes 7 Data sheet 3616.5 ZTRK 2,5/2A/ZS BU Insulated cross-connector Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 9.1 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3710.8 ZQI 2,5/2 YE 4044211060282 50 Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 49.9 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3718.8 ZQI 2,5/10 YE 4044211060367 10 Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 14.2 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3711.8 ZQI 2,5/3 YE 4044211060299 50 Insulated cross-connector, No. of poles: 5, Mounting type: Plug in, Width: 24.4 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3713.8 ZQI 2,5/5 YE 4044211060312 20 Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 39.7 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3716.8 ZQI 2,5/8 YE 4044211060343 10 Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 19.3 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3712.8 ZQI 2,5/4 YE 4044211060305 20 Creation date 17.12.2023 08:49:01 Subject to technical changes 8 Data sheet 3616.5 ZTRK 2,5/2A/ZS BU Insulated cross-connector Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 29.5 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3714.8 ZQI 2,5/6 YE 4044211060329 20 Insulated cross-connector, No. of poles: 99, Mounting type: Plug in, Width: 500 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3719.8 ZQI 2,5/0,5 m/99 Pole YE 4044211060374 2 Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4600.7 PMC SB 5/50 WH 4044211088903 500 ST Four-way cover Cover, Length: 6.7 mm, Width: 20.4 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3706.0 ZAD 2,5/4/B YE 4044211060244 20 ST Reducing sleeves Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 3751.6 ZRH 2,5/0,25-0,5 GR 4044211060602 1000 ST Creation date 17.12.2023 08:49:01 Subject to technical changes 9 Data sheet 3616.5 ZTRK 2,5/2A/ZS BU Reducing sleeves Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 3750.7 ZRH 2,5/0,13-0,2 WH 4044211060596 1000 ST Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3752.4 ZRH 2,5/0,75-1,0 BK 4044211060619 1000 ST Fuse modules Fuse holder, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3632.2 ZS/H2/ZTR/70 4044211059965 20 ST Fuse holder, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3633.2 ZS/H3/ZTR/150 4044211059972 20 ST Fuse holder, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3634.2 ZS/H4/ZTR/250 4044211059989 20 ST Fuse plug, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3635.2 ZS/H0/ZTR 4044211059996 20 ST Creation date 17.12.2023 08:49:01 Subject to technical changes 10 Data sheet 3616.5 ZTRK 2,5/2A/ZS BU Fuse modules Fuse holder, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3631.2 ZS/H1/ZTR/36 4044211059958 20 ST Creation date 17.12.2023 08:49:01 Subject to technical changes 11
3616.5 价格&库存
很抱歉,暂时无法提供与“3616.5”相匹配的价格&库存,您可以联系我们找货
