Data sheet
3627.2 ZTRK 2,5/4A/ZS 36 BG
Fuse-disconnect terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated crosssection: 2.5 mm², Width: 5.1 mm, Colour: Beige
Business data
Article number
3627.2
Article name
GTIN (EAN)
4044211059910
Packaging unit
100
Quantity unit
PC
Weight per piece (not including packaging)
20 g
Weight per piece (including packaging)
21 g
Unit of weight
G
Customs number
85369010
Country of origin
DE
Product description
Creation date 11.11.2023 08:32:48
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
92.4 mm
Width
5.1 mm
Height TS 35/7.5
78.7 mm
Ratings
Rated voltage (determined by the illuminated display
and fuse being used)
36 V
Rated current (as fuse-disconnect terminal)
18 A
Rated cross-section
2.5 mm²
Rated impulse voltage
6 kV
Overvoltage category
III
Contamination degree
3
Connection data
Connection principle
Connection position
Diagonal
Connections
4
Number of terminals per level
4
Number of levels
1
Wire cross-section single-core (rigid) / stranded, min.
0.5 mm²
Wire cross-section single core (rigid)/stranded, max.
4 mm²
Wire cross-section stranded, min.
0.5 mm²
Wire cross-section stranded, max.
4 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.5 mm²
max.
2.5 mm²
Wire cross-section AWG, min.
12
Wire cross-section AWG, max.
Stripping length
10 mm
2
Data sheet
Technical data
Further technical data
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-0
Working temperature, min.
-40 °C
Working temperature, max.
120 °C
Mounting type
Mounting rail TS 35/7,5
Fuse size
5 x 20 mm
Gauge plug acc. to EN 60 947-1
A3
Number of cross-connection channels
1
End plate required
Number of test pick-off options
2
Voltage illuminated display
10-36 V
Cross-current via illuminated display
5 mA
Power loss in singular arrangement - overload and short-circuit protection, max.
2,5 / 6,3 W / A
Power loss in compound arrangement - overload and short-circuit protection, max.
1,6 / 6,3 W / A
Power loss in singular arrangement - only short-circuit protection, max.
4 / 6,3 W / A
Power loss in compound arrangement - only short-circuit protection, max.
2,5 / 6,3 W / A
Version of fuse holder
Pluggable
Type of display element (defect display)
LED
Version of fuse cartridge
G fuse 5 x 20
Supply voltage (defect display), min.
10
Supply voltage (defect display), max.
36
Type of voltage (defect display)
AC/DC
Print
Colour
Beige
Environmental Product Compliance
REACH Conform
Yes
REACH Candidate Substance Note
No
3
Data sheet
Approvals
CSA approval
CSA approval
C22.2 No 158
CSA approval granted
yes
CSA Usegroup B: rated voltage
300 V
CSA Usegroup B: rated current
10 A
CSA Usegroup C: rated voltage
300 V
CSA Usegroup C: rated current
10 A
CSA wire cross-section AWG, min.
CSA wire cross-section AWG, max.
12
CSA stripping length
10 mm
CSAus approval
CSAus approval
UL 1059
CSAus approval granted
yes
CSAus Usegroup B: rated voltage
300 V
CSAus Usegroup B: rated current
10 A
CSAus Usegroup C: rated voltage
300 V
CSAus Usegroup C: rated current
10 A
CSAus wire cross-section AWG, min.
CSAus wire cross-section AWG, max.
12
CSAus stripping length
10 mm
4
Data sheet
Approvals
KEMA KEUR approval
KEMA KEUR approval
EN 60947-7-1:2009, EN 60947-73:2009
KEMA KEUR approval granted
yes
KEMA rated voltage
36 V
KEMA rated current
6,3 A
KEMA rated impulse voltage (fuse holder withoutelectrical components)
6 (4) kV
KEMA wire cross-section single core (rigid), min.
0.5 mm²
KEMA wire cross-section single-core (rigid), max.
4 mm²
KEMA wire cross-section stranded, min.
0.5 mm²
KEMA wire cross-section stranded, max.
4 mm²
KEMA power loss in singular arrangement - overloadand short-circuit
protection, max.
2,5 / 6,3 W / A
KEMA power loss in compound arrangement -overload and short-circuit
protection, max.
1,6 / 6,3 W / A
KEMA power loss in singular arrangement - only short-circuit protection,
max.
4 / 6,3 W / A
KEMA power loss in compound arrangement - only short-circuit
protection, max.
2,5 / 6,3 W / A
5
Data sheet
Media
6
Data sheet
Accessories
End plate
End plate, Width: 1.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3798.2
ZAPT 2,5/4A BG
4044211061326
Actuating tool
End stop
End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 6 mm, Colour:
Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3748.2
ZES 35 BG
4044211060572
50
Test adapter
Test adapter, Pitch size: 5.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3740.2
ZTA 2,5 BG
4044211060497
10 ST
Insulated cross-connector
Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 34.6 mm,
Rated cross-section: 2.5 mm², Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3715.8
ZQI 2,5/7 YE
4044211060336
7
Data sheet
Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 9.1 mm, Rated
Article number
Article name
GTIN (EAN)
Packaging
unit
3710.8
ZQI 2,5/2 YE
4044211060282
50
Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 49.9 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3718.8
ZQI 2,5/10 YE
4044211060367
10
Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 14.2 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3711.8
ZQI 2,5/3 YE
4044211060299
50
Insulated cross-connector, No. of poles: 5, Mounting type: Plug in, Width: 24.4 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3713.8
ZQI 2,5/5 YE
4044211060312
Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 39.7 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3716.8
ZQI 2,5/8 YE
4044211060343
10
Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 19.3 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3712.8
ZQI 2,5/4 YE
4044211060305
8
Data sheet
Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 29.5 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3714.8
ZQI 2,5/6 YE
4044211060329
Insulated cross-connector, No. of poles: 99, Mounting type: Plug in, Width: 500 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
3719.8
ZQI 2,5/0,5 m/99 Pole YE
4044211060374
2
Quick marking
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
4600.7
PMC SB 5/50 WH
4044211088903
500 ST
Four-way cover
Cover, Length: 6.7 mm, Width: 20.4 mm, Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3706.0
ZAD 2,5/4/B YE
4044211060244
20 ST
9
