3636.1
3636.1
    CONTA-CLIP
    FEED-THROUGH TERMINAL
3636.1 数据手册
Data sheet 3636.1 ZRK 16/2A GN Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated crosssection: 16 mm², Width: 12.1 mm, Colour: Green Business data Article number 3636.1 Article name ZRK 16/2A GN GTIN (EAN) 4044211152123 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 35.4 g Weight per piece (including packaging) 36.45 g Unit of weight G Customs number 85369010 Country of origin CZ Prio-Article 3636.2 Product description Feed-through terminal Creation date 17.12.2023 03:42:47 Subject to technical changes 1 Data sheet 3636.1 ZRK 16/2A GN Technical data Dimensions Length 81.5 mm Width 12.1 mm Height TS 35/7.5 51.5 mm Ratings Rated voltage 1000 V Rated current 76 A Rated cross-section 16 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 2.43 W Connection data Connection principle Tension-spring connection Connection position Diagonal Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 1.5 mm² Wire cross-section single core (rigid)/stranded, max. 25 mm² Wire cross-section stranded, min. 1.5 mm² Wire cross-section stranded, max. 16 mm² Wire cross-section stranded with wire-end ferrules, min. 1.5 mm² Wire cross-section stranded with wire-end ferrules, max. 16 mm² Wire cross-section AWG, min. 14 Wire cross-section AWG, max. 4 Stripping length 18 mm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 17.12.2023 03:42:47 Subject to technical changes 2 Data sheet 3636.1 ZRK 16/2A GN Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A7 Number of cross-connection channels 2 End plate required Number of test pick-off options 2 Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 03:42:47 No Subject to technical changes 3 Data sheet 3636.1 ZRK 16/2A GN Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 1000 V CSA Usegroup C: rated current 65 A CSA wire cross-section AWG, min. 14 CSA wire cross-section AWG, max. 4 CSA stripping length 18 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 1000 V CSAus Usegroup C: rated current 65 A CSAus wire cross-section AWG, min. 14 CSAus wire cross-section AWG, max. 4 CSAus stripping length 18 mm KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 1000 V KEMA rated current 76 A KEMA rated impulse voltage 8 kV KEMA wire cross-section single core (rigid), min. 1.5 mm² KEMA wire cross-section single-core (rigid), max. 25 mm² KEMA wire cross-section stranded, min. 1.5 mm² KEMA wire cross-section stranded, max. 16 mm² Creation date 17.12.2023 03:42:47 Subject to technical changes 4 Data sheet 3636.1 ZRK 16/2A GN Approvals UL Recognized UL approval UL 1059 UL Usegroup E: rated voltage 1000 V UL Usegroup E: rated current 65 A UL wire cross-section single-core (rigid) AWG, min. 14 UL wire cross-section single-core (rigid) AWG, max. 4 UL wire cross-section stranded AWG, min. 14 UL wire cross-section stranded AWG, max. 4 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 17.12.2023 03:42:47 Subject to technical changes 5 Data sheet 3636.1 ZRK 16/2A GN Media Creation date 17.12.2023 03:42:47 Subject to technical changes 6 Data sheet 3636.1 ZRK 16/2A GN Accessories End plate End plate, Width: 2 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3799.2 ZAP 16/2A BG 4044211080204 20 End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3748.2 ZES 35 BG 4044211060572 50 Insulated cross-connector Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 20.4 mm, Rated cross-section: 16 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3800.8 ZQI 16/2 YE 4044211080181 20 ST Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9323.7 PMC SB 8/40 WH 4044211129231 400 ST Four-way cover Creation date 17.12.2023 03:42:47 Subject to technical changes 7 Data sheet 3636.1 ZRK 16/2A GN Cover, Width: 48.4 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3801.0 ZAD 16/4/B YE 4044211080235 20 ST Creation date 17.12.2023 03:42:47 Subject to technical changes 8
3636.1 价格&库存
很抱歉,暂时无法提供与“3636.1”相匹配的价格&库存,您可以联系我们找货
