3671.5
3671.5
    CONTA-CLIP
    接线端子 1x1P 自由悬挂(直插式)
3671.5 数据手册
Data sheet 3671.5 ZST 2,5/1A/Z BU Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 3671.5 Article name ZST 2,5/1A/Z BU GTIN (EAN) 4044211182687 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 2.7 g Weight per piece (including packaging) 3.17 g Unit of weight G Customs number 85369010 Country of origin CZ Prio-Article 3671.2 Product description Feed-through terminal Creation date 17.12.2023 08:51:52 Subject to technical changes 1 Data sheet 3671.5 ZST 2,5/1A/Z BU Technical data Dimensions Length 42 mm Width 5.1 mm Height 16.5 mm Pitch 5 mm Ratings Rated voltage 500 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Tension-spring connection Connections 1 No. of poles 1 Wire cross-section single-core (rigid) / stranded, min. 0.5 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.5 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.5 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Wire cross-section AWG, min. 20 Wire cross-section AWG, max. 12 Stripping length 10 mm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 17.12.2023 08:51:52 Subject to technical changes 2 Data sheet 3671.5 ZST 2,5/1A/Z BU Technical data Further technical data Mounting type Plug in Gauge plug acc. to EN 60 947-1 A3 End plate required Number of test pick-off options 1 Can be mounted side-by-side Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 08:51:52 No Subject to technical changes 3 Data sheet 3671.5 ZST 2,5/1A/Z BU Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 300 V CSA Usegroup C: rated current 20 A CSA wire cross-section AWG, min. 20 CSA wire cross-section AWG, max. 12 CSA stripping length 10 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 300 V CSAus Usegroup C: rated current 20 A CSAus wire cross-section AWG, min. 20 CSAus wire cross-section AWG, max. 12 CSAus stripping length 10 mm cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 20 A cUL Usegroup C: rated voltage 300 V cUL Usegroup C: rated current 20 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 20 A cUL wire cross-section single-core (rigid) AWG, min. 20 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 20 cUL wire cross-section stranded AWG, max. 12 cUL wire material Cu cUL Recognized 1 Creation date 17.12.2023 08:51:52 Subject to technical changes 4 Data sheet 3671.5 ZST 2,5/1A/Z BU Approvals KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 500 V KEMA rated current 24 A KEMA rated impulse voltage 6 kV KEMA wire cross-section single core (rigid), min. 0.5 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.5 mm² KEMA wire cross-section stranded, max. 4 mm² UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 20 A UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 20 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 20 A UL wire cross-section single-core (rigid) AWG, min. 20 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 20 UL wire cross-section stranded AWG, max. 12 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 17.12.2023 08:51:52 Subject to technical changes 5 Data sheet 3671.5 ZST 2,5/1A/Z BU Media Creation date 17.12.2023 08:51:52 Subject to technical changes 6 Data sheet 3671.5 ZST 2,5/1A/Z BU Accessories End plate End plate, Width: 0.6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3684.2 ZAPST 2,5/1A BG 4044211177621 50 Actuating tool Actuating tool, No. of poles: 1, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3808.0 BWMA 1 (0,5 x 3,5 mm) 4044211078850 1 ST Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4600.7 PMC SB 5/50 WH 4044211088903 500 ST Four-way cover Cover, Length: 6.7 mm, Width: 20.4 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3706.0 ZAD 2,5/4/B YE 4044211060244 20 ST ZST-strain relief Creation date 17.12.2023 08:51:52 Subject to technical changes 7 Data sheet 3671.5 ZST 2,5/1A/Z BU Strain relief, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 3688.3 ZST-Z OG 4044211177928 50 ST Creation date 17.12.2023 08:51:52 Subject to technical changes 8
3671.5
物料型号:3671.5 ZST 2,5/1A/Z BU
器件简介:这是一个穿墙端子,采用张力弹簧连接方式,插入式安装,额定截面积为2.5 mm²,宽度为5.1 mm,颜色为蓝色。
引脚分配:该端子具有1个连接点,适用于单极连接。
参数特性: - 长度:42mm - 宽度:5.1 mm - 高度:16.5 mm - 间距:5mm - 额定电压:500V - 额定截面积:2.5 mm² - 额定冲击电压:6kV - 污染等级:3 - 工作温度范围:-40°C 至 120°C
功能详解:该端子采用张力弹簧连接原理,适用于不同截面积的单芯或绞合导线。
应用信息:文档中未提供具体的应用信息,但根据其特性,它可能用于电气连接,尤其是在需要穿墙或需要高机械稳定性的应用中。
封装信息:绝缘材料为聚酰胺6.6,阻燃等级为UL 94 V-0。
3671.5 价格&库存
很抱歉,暂时无法提供与“3671.5”相匹配的价格&库存,您可以联系我们找货
