3676.0
3676.0
    CONTA-CLIP
    板对板连接器
3676.0 数据手册
Data sheet 3676.0 ZSTK 2,5/1A/1S-H/15 GNYE Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 15/5.5, Rated crosssection: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow Business data Article number 3676.0 Article name ZSTK 2,5/1A/1S-H/15 GNYE GTIN (EAN) 4044211182373 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 3.7 g Weight per piece (including packaging) 4.2 g Unit of weight G Customs number 85369010 Country of origin CZ Prio-Article 3676.2 Product description Feed-through terminal Creation date 15.12.2023 06:24:17 Subject to technical changes 1 Data sheet 3676.0 ZSTK 2,5/1A/1S-H/15 GNYE Technical data Dimensions Length 40 mm Width 5.1 mm Height 32 mm Height TS 15/5.5 33 mm Pitch 5 mm Ratings Rated voltage 500 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 0.77 W Connection data Connection principle Tension-spring connection Connection position Top Connections 2 No. of poles 1 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.5 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.5 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.5 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Wire cross-section AWG, min. 20 Wire cross-section AWG, max. 12 Stripping length 10 mm Creation date 15.12.2023 06:24:17 Subject to technical changes 2 Data sheet 3676.0 ZSTK 2,5/1A/1S-H/15 GNYE Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Further technical data Mounting type TS 15 Gauge plug acc. to EN 60 947-1 A3 End plate required Number of test pick-off options 1 Environmental Product Compliance REACH Candidate Substance Note Creation date 15.12.2023 06:24:17 No Subject to technical changes 3 Data sheet 3676.0 ZSTK 2,5/1A/1S-H/15 GNYE Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 300 V CSA Usegroup C: rated current 20 A CSA wire cross-section AWG, min. 20 CSA wire cross-section AWG, max. 12 CSA stripping length 10 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 300 V CSAus Usegroup C: rated current 20 A CSAus wire cross-section AWG, min. 20 CSAus wire cross-section AWG, max. 12 CSAus stripping length 10 mm cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 20 A cUL Usegroup C: rated voltage 300 V cUL Usegroup C: rated current 20 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 20 A cUL wire cross-section single-core (rigid) AWG, min. 20 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 20 cUL wire cross-section stranded AWG, max. 12 cUL wire material Cu cUL Recognized 1 Creation date 15.12.2023 06:24:17 Subject to technical changes 4 Data sheet 3676.0 ZSTK 2,5/1A/1S-H/15 GNYE Approvals KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 500 V KEMA rated current 24 A KEMA rated impulse voltage 6 kV KEMA wire cross-section single core (rigid), min. 0.5 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.5 mm² KEMA wire cross-section stranded, max. 4 mm² UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 20 A UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 20 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 20 A UL wire cross-section single-core (rigid) AWG, min. 20 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 20 UL wire cross-section stranded AWG, max. 12 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 15.12.2023 06:24:17 Subject to technical changes 5 Data sheet 3676.0 ZSTK 2,5/1A/1S-H/15 GNYE Media Creation date 15.12.2023 06:24:17 Subject to technical changes 6 Data sheet 3676.0 ZSTK 2,5/1A/1S-H/15 GNYE Accessories End plate End plate, Width: 0.6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3686.2 ZAPSK 2,5/1A/1S BG 4044211177645 50 Actuating tool Actuating tool, No. of poles: 1, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3808.0 BWMA 1 (0,5 x 3,5 mm) 4044211078850 1 ST Coding Coding, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 3689.3 ZST-C OG 4044211177805 50 ST End stop End stop, Mounting type: Mounting rail TS 15/5.5, Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3812.2 ZES 15 BG 4044211080617 50 ST Quick marking Creation date 15.12.2023 06:24:17 Subject to technical changes 7 Data sheet 3676.0 ZSTK 2,5/1A/1S-H/15 GNYE Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4600.7 PMC SB 5/50 WH 4044211088903 500 ST Locking mechanism Locking mechanism, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 3687.3 ZST-V OG 4044211177911 50 ST Four-way cover Cover, Length: 6.7 mm, Width: 20.4 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3706.0 ZAD 2,5/4/B YE 4044211060244 20 ST ZST-strain relief Strain relief, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 3688.3 ZST-Z OG 4044211177928 50 ST Creation date 15.12.2023 06:24:17 Subject to technical changes 8
3676.0 价格&库存
很抱歉,暂时无法提供与“3676.0”相匹配的价格&库存,您可以联系我们找货
