3681.2
3681.2
    CONTA-CLIP
    END PLATE
3681.2 数据手册
Data sheet 3681.2 ZAPS 2,5/1A/2S BG End plate, Width: 1.5 mm, Colour: Beige Business data Article number 3681.2 Article name ZAPS 2,5/1A/2S BG GTIN (EAN) 4044211177591 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 2.75 g Weight per piece (including packaging) 2.85 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3681.2 Product description End plate Creation date 16.12.2023 11:45:48 Subject to technical changes 1 Data sheet 3681.2 ZAPS 2,5/1A/2S BG Technical data Dimensions Length 72.3 mm Width 1.5 mm Height 31 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 11:45:48 No Subject to technical changes 2 Data sheet 3681.2 ZAPS 2,5/1A/2S BG Media Creation date 16.12.2023 11:45:48 Subject to technical changes 3 Data sheet 3681.2 ZAPS 2,5/1A/2S BG Accessories ##INVERSE##CONTA-CONNECT Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3651.2 ZRKS 2,5/1A/2S BG 4044211177669 100 Protective earth terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3661.2 ZSLS 2,5/1A/2S GNYE 4044211177737 100 ST Creation date 16.12.2023 11:45:48 Subject to technical changes 4
3681.2 价格&库存
很抱歉,暂时无法提供与“3681.2”相匹配的价格&库存,您可以联系我们找货
    • 50+8.1407050+1.05519
