Data sheet
3682.2 ZAPS 2,5/2A/1S BG
End plate, Width: 1.5 mm, Colour: Beige
Business data
Article number
3682.2
Article name
ZAPS 2,5/2A/1S BG
GTIN (EAN)
4044211177607
Packaging unit
50
Quantity unit
PC
Weight per piece (not including packaging)
0.28 g
Weight per piece (including packaging)
0.29 g
Unit of weight
G
Customs number
85389099
Country of origin
DE
Prio-Article
3682.2
Product description
End plate
Creation date 17.12.2023 08:51:53
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
63.7 mm
Width
1.5 mm
Height
31 mm
Materials
Material
Polyamide 6.6
Flammability class UL 94
V-0
Working temperature, min.
-40 °C
Working temperature, max.
120 °C
Further technical data
Designed as end plate
Snap-on available
Environmental Product Compliance
REACH Candidate Substance Note
No
2
Data sheet
Media
3
Data sheet
Accessories
##INVERSE##CONTA-CONNECT
Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS
35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3652.2
ZRKS 2,5/2A/1S BG
4044211177676
100
Protective earth terminal, Tension-spring connection, Mounting type: Mounting rail TS
35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3662.2
ZSLS 2,5/2A/1S GNYE
4044211177744
100 ST
4
很抱歉,暂时无法提供与“3682.2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+8.1407050+1.05519
