3684.1
3684.1
    CONTA-CLIP
    END PLATE
3684.1 数据手册
Data sheet 3684.1 ZAPST 2,5/1A GN End plate, Width: 0.6 mm, Colour: Green Business data Article number 3684.1 Article name ZAPST 2,5/1A GN GTIN (EAN) 4044211182588 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 0.21 g Weight per piece (including packaging) 0.22 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3684.2 Product description End plate Creation date 17.12.2023 08:52:16 Subject to technical changes 1 Data sheet 3684.1 ZAPST 2,5/1A GN Technical data Dimensions Length 39 mm Width 0.6 mm Height 14.7 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 08:52:16 No Subject to technical changes 2 Data sheet 3684.1 ZAPST 2,5/1A GN Media Creation date 17.12.2023 08:52:16 Subject to technical changes 3 Data sheet 3684.1 ZAPST 2,5/1A GN Accessories ##INVERSE##CONTA-CONNECT Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3671.2 ZST 2,5/1A/Z BG 4044211177829 100 Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3670.2 ZST 2,5/1A BG 4044211177812 100 Creation date 17.12.2023 08:52:16 Subject to technical changes 4
3684.1 价格&库存
很抱歉,暂时无法提供与“3684.1”相匹配的价格&库存,您可以联系我们找货
