3686.5
3686.5
    CONTA-CLIP
    END PLATE
3686.5 数据手册
Data sheet 3686.5 ZAPSK 2,5/1A/1S BU End plate, Width: 0.6 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 3686.5 Article name ZAPSK 2,5/1A/1S BU GTIN (EAN) 4044211182328 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 0.85 g Weight per piece (including packaging) 0.86 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3686.2 Product description End plate Creation date 15.12.2023 00:50:26 Subject to technical changes 1 Data sheet 3686.5 ZAPSK 2,5/1A/1S BU Technical data Dimensions Length 39.8 mm Width 0.6 mm Height 18.8 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 15.12.2023 00:50:26 No Subject to technical changes 2 Data sheet 3686.5 ZAPSK 2,5/1A/1S BU Media Creation date 15.12.2023 00:50:26 Subject to technical changes 3 Data sheet 3686.5 ZAPSK 2,5/1A/1S BU Accessories ##INVERSE##CONTA-CONNECT Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3679.2 ZSTK 2,5/1A/1S-H/Z/B BG 4044211177904 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 15/5.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3668.2 ZSTK 2,5/1A/1S-H/Z/B/15 BG 4044211177799 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3675.2 ZSTK 2,5/1A/1S-H/Z/35 BG 4044211177867 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3667.2 ZSTK 2,5/1A/1S-H/Z/B/35 BG 4044211177782 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3674.2 ZSTK 2,5/1A/1S-H/35 BG 4044211177850 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 15/5.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3677.2 ZSTK 2,5/1A/1S-H/Z/15 BG 4044211177881 100 Creation date 15.12.2023 00:50:26 Subject to technical changes 4 Data sheet 3686.5 ZAPSK 2,5/1A/1S BU ##INVERSE##CONTA-CONNECT Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 15/5.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3676.2 ZSTK 2,5/1A/1S-H/15 BG 4044211177874 100 Creation date 15.12.2023 00:50:26 Subject to technical changes 5
3686.5 价格&库存
很抱歉,暂时无法提供与“3686.5”相匹配的价格&库存,您可以联系我们找货
