3685.1
3685.1
    CONTA-CLIP
    END PLATE
3685.1 数据手册
Data sheet 3685.1 ZAPST 2,5/1A/Q GN End plate, Width: 0.6 mm, Colour: Green-yellow Business data Article number 3685.1 Article name ZAPST 2,5/1A/Q GN GTIN (EAN) 4044211182618 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 0.25 g Weight per piece (including packaging) 0.26 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3685.2 Product description End plate Creation date 17.12.2023 08:50:08 Subject to technical changes 1 Data sheet 3685.1 ZAPST 2,5/1A/Q GN Technical data Dimensions Length 39 mm Width 0.6 mm Height 19.4 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 08:50:08 No Subject to technical changes 2 Data sheet 3685.1 ZAPST 2,5/1A/Q GN Media Creation date 17.12.2023 08:50:08 Subject to technical changes 3 Data sheet 3685.1 ZAPST 2,5/1A/Q GN Accessories ##INVERSE##CONTA-CONNECT Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3673.2 ZST 2,5/1A/Q/Z BG 4044211177843 100 Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3672.2 ZST 2,5/1A/Q BG 4044211177836 100 Creation date 17.12.2023 08:50:08 Subject to technical changes 4
3685.1 价格&库存
很抱歉,暂时无法提供与“3685.1”相匹配的价格&库存,您可以联系我们找货
