3692.1
3692.1
    CONTA-CLIP
    END PLATE
3692.1 数据手册
Data sheet 3692.1 ZAPS 2,5/4S GN End plate, Width: 1.5 mm, Colour: Green Business data Article number 3692.1 Article name ZAPS 2,5/4S GN GTIN (EAN) 4044211185886 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 3.5 g Weight per piece (including packaging) 3.6 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3692.1 Product description End plate Creation date 17.12.2023 03:24:19 Subject to technical changes 1 Data sheet 3692.1 ZAPS 2,5/4S GN Technical data Dimensions Length 90.7 mm Width 1.5 mm Height 31 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 03:24:19 No Subject to technical changes 2 Data sheet 3692.1 ZAPS 2,5/4S GN Media Creation date 17.12.2023 03:24:19 Subject to technical changes 3 Data sheet 3692.1 ZAPS 2,5/4S GN Accessories ##INVERSE##CONTA-CONNECT Protective earth terminal, Plug-in connection, Mounting type: Mounting rail TS 35/7.5, Width: 5.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3664.2 ZSLS 2,5/4S GNYE 4044211177768 100 ST Feed-through terminal, Plug-in connection, Mounting type: Mounting rail TS 35/7.5, Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3654.2 ZRKS 2,5/4S BG 4044211177690 100 Creation date 17.12.2023 03:24:19 Subject to technical changes 4
3692.1 价格&库存
很抱歉,暂时无法提供与“3692.1”相匹配的价格&库存,您可以联系我们找货
    • 50+8.1470650+1.05519
