Data sheet
3700.2 ZAP 2,5/2A BG
End plate, Width: 2 mm, Colour: Beige
Business data
Article number
3700.2
Article name
ZAP 2,5/2A BG
GTIN (EAN)
4044211060015
Packaging unit
50
Quantity unit
PC
Weight per piece (not including packaging)
2.4 g
Weight per piece (including packaging)
2.5 g
Unit of weight
G
Customs number
85389099
Country of origin
DE
Prio-Article
3700.2
Product description
End plate
Creation date 17.12.2023 08:52:45
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
59 mm
Width
2 mm
Height
30.8 mm
Materials
Material
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Designed as end plate
Snap-on available
Environmental Product Compliance
REACH Conform
Yes
REACH Candidate Substance Note
No
2
Data sheet
Media
3
Data sheet
Accessories
##INVERSE##CONTA-CONNECT
Ex protective-earth terminal ATEX-certified Tension-spring connection, Mounting type:
Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Greenyellow
Article number
Article name
GTIN (EAN)
Packaging
unit
1713.2
ZSL 2,5/2A Ex GNYE
4044211058548
100 ST
Protective earth terminal, Tension-spring connection, Mounting type: Mounting rail TS
35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3510.2
ZSL 2,5/2A GNYE
4044211151720
100 ST
Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type:
Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
1704.2
ZRK 2,5/2A Ex BG
4044211058401
100
Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS
Article number
Article name
GTIN (EAN)
Packaging
unit
1169.2
ZSRK 2,5/2A/SAS BG
4044211128647
100
Article number
Article name
GTIN (EAN)
Packaging
unit
3500.2
ZRK 2,5/2A BG
4044211151683
100
4
很抱歉,暂时无法提供与“3700.2”相匹配的价格&库存,您可以联系我们找货
