3702.5
3702.5
    CONTA-CLIP
    END PLATE
3702.5 数据手册
Data sheet 3702.5 ZAP 2,5/4A BU End plate, Width: 2 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 3702.5 Article name ZAP 2,5/4A BU GTIN (EAN) 4044211060114 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 3g Weight per piece (including packaging) 3.1 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3702.2 Product description End plate Creation date 16.12.2023 18:33:50 Subject to technical changes 1 Data sheet 3702.5 ZAP 2,5/4A BU Technical data Dimensions Length 83.6 mm Width 2 mm Height 30.8 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 18:33:50 No Subject to technical changes 2 Data sheet 3702.5 ZAP 2,5/4A BU Media Creation date 16.12.2023 18:33:50 Subject to technical changes 3 Data sheet 3702.5 ZAP 2,5/4A BU Accessories ##INVERSE##CONTA-CONNECT Protective earth terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3512.2 ZSL 2,5/4A GNYE 4044211058562 100 ST Ex protective-earth terminal ATEX-certified Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Greenyellow Article number Article name GTIN (EAN) Packaging unit 1715.2 ZSL 2,5/4A Ex GNYE 4044211058555 100 ST Double-level terminal with electronic components, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3505.2 ZRK 2,5/2x2A/LED1(RD)/24V DC BG 4044211058531 100 ST Double-level terminal with electronic components, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3543.2 ZRK 2,5/2x2A/LED2(RD)/24V DC BG 4044211058845 100 ST Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1706.2 ZRK 2,5/4A Ex BG 4044211058463 100 Creation date 16.12.2023 18:33:50 Subject to technical changes 4 Data sheet 3702.5 ZAP 2,5/4A BU ##INVERSE##CONTA-CONNECT Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3503.2 ZRK 2,5/2x2A BG 4044211058494 100 Double-level terminal with electronic components, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3504.2 ZRK 2,5/2x2A/D1 BG 4044211058524 100 ST Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3502.2 ZRK 2,5/4A BG 4044211151713 100 Double-level terminal with electronic components, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3542.2 ZRK 2,5/2x2A/D2 BG 4044211058838 100 ST Creation date 16.12.2023 18:33:50 Subject to technical changes 5
3702.5 价格&库存
很抱歉,暂时无法提供与“3702.5”相匹配的价格&库存,您可以联系我们找货
    • 50+8.6956550+1.12713
