3703.9
3703.9
    CONTA-CLIP
    END PLATE
3703.9 数据手册
Data sheet 3703.9 ZAP 4/2A RD End plate, Width: 2 mm, Colour: Red Business data Article number 3703.9 Article name ZAP 4/2A RD GTIN (EAN) 4044211108052 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 2.6 g Weight per piece (including packaging) 2.7 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3703.2 Product description End plate Creation date 16.12.2023 18:54:56 Subject to technical changes 1 Data sheet 3703.9 ZAP 4/2A RD Technical data Dimensions Length 64 mm Width 2 mm Height 33.9 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 18:54:56 No Subject to technical changes 2 Data sheet 3703.9 ZAP 4/2A RD Media Creation date 16.12.2023 18:54:56 Subject to technical changes 3 Data sheet 3703.9 ZAP 4/2A RD Accessories ##INVERSE##CONTA-CONNECT Protective earth terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3525.2 ZSL 4/2A GNYE 4044211151799 100 ST Ex protective-earth terminal ATEX-certified Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Greenyellow Article number Article name GTIN (EAN) Packaging unit 1722.2 ZSL 4/2A Ex GNYE 4044211058692 100 ST Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3515.2 ZRK 4/2A BG 4044211151751 100 Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1716.2 ZRK 4/2A Ex BG 4044211058579 100 Creation date 16.12.2023 18:54:56 Subject to technical changes 4
3703.9 价格&库存
很抱歉,暂时无法提供与“3703.9”相匹配的价格&库存,您可以联系我们找货
