Data sheet
3704.3 ZAP 4/3A OG
End plate, Width: 2 mm, Colour: Orange
Business data
Article number
3704.3
Article name
ZAP 4/3A OG
GTIN (EAN)
4044211060183
Packaging unit
50
Quantity unit
PC
Weight per piece (not including packaging)
2.4 g
Weight per piece (including packaging)
2.5 g
Unit of weight
G
Customs number
85389099
Country of origin
DE
Prio-Article
3704.2
Product description
End plate
Creation date 17.12.2023 08:52:15
Subject to technical changes
1
Data sheet
3704.3 ZAP 4/3A OG
Technical data
Dimensions
Length
78.5 mm
Width
2 mm
Height
33.9 mm
Materials
Material
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Designed as end plate
Snap-on available
Environmental Product Compliance
REACH Candidate Substance Note
No
2
Data sheet
3704.3 ZAP 4/3A OG
Media
3
Data sheet
3704.3 ZAP 4/3A OG
Accessories
##INVERSE##CONTA-CONNECT
Protective earth terminal, Tension-spring connection, Mounting type: Mounting rail TS
35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Green-yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3526.2
ZSL 4/3A GNYE
4044211151805
100 ST
Ex protective-earth terminal ATEX-certified Tension-spring connection, Mounting type:
Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Greenyellow
Article number
Article name
GTIN (EAN)
Packaging
unit
1723.2
ZSL 4/3A Ex GNYE
4044211058708
100 ST
Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type:
Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
1717.2
ZRK 4/3A Ex BG
4044211058609
100
Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS
Article number
Article name
GTIN (EAN)
Packaging
unit
3516.2
ZRK 4/3A BG
4044211151775
100
4
很抱歉,暂时无法提供与“3704.3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+8.9153150+1.15079
