Data sheet
3705.1 ZAP 4/4A GN
End plate, Width: 2 mm, Colour: Green
Business data
Article number
3705.1
Article name
ZAP 4/4A GN
GTIN (EAN)
4044211060206
Packaging unit
50
Quantity unit
PC
Weight per piece (not including packaging)
2.4 g
Weight per piece (including packaging)
2.5 g
Unit of weight
G
Customs number
85389099
Country of origin
DE
Prio-Article
3705.2
Product description
End plate
Creation date 17.12.2023 08:52:33
Subject to technical changes
1
Data sheet
3705.1 ZAP 4/4A GN
Technical data
Dimensions
Length
93 mm
Width
2 mm
Height
33.9 mm
Materials
Material
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Designed as end plate
Snap-on available
Environmental Product Compliance
REACH Conform
Yes
REACH Candidate Substance Note
No
2
Data sheet
3705.1 ZAP 4/4A GN
Media
3
Data sheet
3705.1 ZAP 4/4A GN
Accessories
##INVERSE##CONTA-CONNECT
Protective earth terminal, Tension-spring connection, Mounting type: Mounting rail TS
35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Green-yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3527.2
ZSL 4/4A GNYE
4044211151812
100 ST
Ex protective-earth terminal ATEX-certified Tension-spring connection, Mounting type:
Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Greenyellow
Article number
Article name
GTIN (EAN)
Packaging
unit
1724.2
ZSL 4/4A Ex GNYE
4044211058715
100 ST
Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS
35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3518.2
ZRK 4/2x2A BG
4044211058661
100
Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type:
Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
1718.2
ZRK 4/4A Ex BG
4044211058630
100
Article number
Article name
GTIN (EAN)
Packaging
unit
3517.2
ZRK 4/4A BG
4044211151782
100
4
很抱歉,暂时无法提供与“3705.1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+9.2308650+1.19556
