3712.5
3712.5
    CONTA-CLIP
    INSULATED CROSS CONNECTOR
3712.5 数据手册
Data sheet 3712.5 ZQI 2,5/4 BU Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 19.3 mm, Rated cross-section: 2.5 mm², Colour: Blue RAL: Ähnlich 5005 Business data Article number 3712.5 Article name ZQI 2,5/4 BU GTIN (EAN) 4044211108519 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 2.26 g Weight per piece (including packaging) 2.36 g Unit of weight G Customs number 85389099 Country of origin CZ Prio-Article 3712.8 Product description Insulated cross-connector Creation date 17.12.2023 08:55:42 Subject to technical changes 1 Data sheet 3712.5 ZQI 2,5/4 BU Technical data Dimensions Length 4.5 mm Width 19.3 mm Pitch size 5 mm Ratings Voltage with partition, max. 800 V Voltage without partition, max. 800 V Rated current 24 A Rated cross-section 2.5 mm² Contamination degree 3 Connection data No. of poles 4 Materials Material Copper alloy Surface Tin-plated Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Plug in Insulation available Touch protection is available Number of bridged terminals 4 Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 08:55:42 No Subject to technical changes 2 Data sheet 3712.5 ZQI 2,5/4 BU Media Creation date 17.12.2023 08:55:42 Subject to technical changes 3 Data sheet 3712.5 ZQI 2,5/4 BU Accessories ##INVERSE##CONTA-CONNECT Double-level terminal with electronic components, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3568.2 ZRKD 2,5/LED1(RD)/24V DC BG 4044211059125 100 ST Double-level terminal with electronic components, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3569.2 ZRKD 2,5/LED2(RD)/24V DC BG 4044211059132 100 ST Double-level terminal with electronic components, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3572.2 ZRKD 2,5/D3 BG 4044211059163 100 Double-level terminal with electronic components, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3573.2 ZRKD 2,5/D4 BG 4044211059170 100 Double-level terminal with electronic components, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3574.2 ZRKD 2,5/D5 BG 4044211059187 100 ST Creation date 17.12.2023 08:55:42 Subject to technical changes 4 Data sheet 3712.5 ZQI 2,5/4 BU ##INVERSE##CONTA-CONNECT Double-level terminal with electronic components, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3645.2 ZRKD 2,5/LED(RD)/230V AC BG 4044211146733 100 ST Double-level terminal with electronic components, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3570.2 ZRKD 2,5/D1 BG 4044211059149 100 Double-level terminal with electronic components, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3571.2 ZRKD 2,5/D2 BG 4044211059156 100 Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17481.2 ZST 2,5/1/1A/Q BG 4044211205201 50 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 66.3 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17493.2 ZST 2,5/13/1A/Q BG 4044211205324 10 ST Creation date 17.12.2023 08:55:42 Subject to technical changes 5 Data sheet 3712.5 ZQI 2,5/4 BU ##INVERSE##CONTA-CONNECT Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 71.4 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17494.2 ZST 2,5/14/1A/Q BG 4044211205331 10 ST Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3653.2 ZRKS 2,5/2A/2S BG 4044211177683 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3652.2 ZRKS 2,5/2A/1S BG 4044211177676 100 Feed-through terminal, Plug-in connection, Mounting type: Mounting rail TS 35/7.5, Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3655.2 ZRKS 2,5/2S BG 4044211177706 100 Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 25.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17485.2 ZST 2,5/5/1A/Q BG 4044211205249 50 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 56.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17491.2 ZST 2,5/11/1A/Q BG 4044211205300 10 ST Creation date 17.12.2023 08:55:42 Subject to technical changes 6 Data sheet 3712.5 ZQI 2,5/4 BU ##INVERSE##CONTA-CONNECT Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 76.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17495.2 ZST 2,5/15/1A/Q BG 4044211205348 10 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 816 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17496.2 ZST 2,5/16/1A/Q BG 4044211205355 10 ST Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3650.2 ZRKS 2,5/1A/1S BG 4044211177652 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3651.2 ZRKS 2,5/1A/2S BG 4044211177669 100 Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 45.9 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17489.2 ZST 2,5/9/1A/Q BG 4044211205287 25 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 51 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17490.2 ZST 2,5/10/1A/Q BG 4044211205294 25 ST Creation date 17.12.2023 08:55:42 Subject to technical changes 7 Data sheet 3712.5 ZQI 2,5/4 BU ##INVERSE##CONTA-CONNECT Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3673.2 ZST 2,5/1A/Q/Z BG 4044211177843 100 Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 20.4 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17484.2 ZST 2,5/4/1A/Q BG 4044211205232 50 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 35.7 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17487.2 ZST 2,5/7/1A/Q BG 4044211205263 25 ST Feed-through terminal, Plug-in connection, Mounting type: Mounting rail TS 35/7.5, Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3654.2 ZRKS 2,5/4S BG 4044211177690 100 Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 10.2 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17482.2 ZST 2,5/2/1A/Q BG 4044211205218 50 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 15.3 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17483.2 ZST 2,5/3/1A/Q BG 4044211205225 50 ST Creation date 17.12.2023 08:55:42 Subject to technical changes 8 Data sheet 3712.5 ZQI 2,5/4 BU ##INVERSE##CONTA-CONNECT Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 40.8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17488.2 ZST 2,5/8/1A/Q BG 4044211205270 25 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 61.2 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17492.2 ZST 2,5/12/1A/Q BG 4044211205317 10 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3672.2 ZST 2,5/1A/Q BG 4044211177836 100 Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 30.6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17486.2 ZST 2,5/6/1A/Q BG 4044211205256 25 ST Ex feed-through terminal for direct mount, ATEX-certified, Tension-spring connection, Mounting type: Mounting surface, Rated cross-section: 25 mm², Width: 51 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1729.2 ZSRK 2,5/2A-D Ex BG 4044211129699 100 ST Feed-through terminal for direct mount, Tension-spring connection, Mounting type: Mounting surface, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3588.2 ZSRK 2,5/2A-D BG 4044211151966 100 Creation date 17.12.2023 08:55:42 Subject to technical changes 9 Data sheet 3712.5 ZQI 2,5/4 BU ##INVERSE##CONTA-CONNECT Feed-through terminal for direct mount, Tension-spring connection, Mounting type: Mounting surface, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 3638.2 ZSLN 2,5/2A-D BKYE 4044211080570 100 ST Feed-through terminal for direct mount, Tension-spring connection, Mounting type: Mounting surface, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 3639.2 ZSLN 2,5/2A-RC BKYE 4044211080556 100 ST Feed-through terminal for direct mount, Tension-spring connection, Mounting type: Mounting surface, Rated cross-section: 2.5 mm², Width: 11.1 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 3640.2 ZSLN 2,5/2A-D/F BKYE 4044211080563 50 ST Feed-through terminal for direct mount, Tension-spring connection, Mounting type: Mounting surface, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3587.2 ZSRK 2,5/2A-RC BG 4044211151942 100 Feed-through terminal for direct mount, Tension-spring connection, Mounting type: Mounting surface, Rated cross-section: 2.5 mm², Width: 11.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3595.2 ZSRK 2,5/2A/D/F BG 4044211059545 50 Fuse-disconnect terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3616.2 ZTRK 2,5/2A/ZS BG 4044211059804 100 Creation date 17.12.2023 08:55:42 Subject to technical changes 10 Data sheet 3712.5 ZQI 2,5/4 BU ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3621.2 ZTRK 2,5/3A/ZS BG 4044211059859 100 Fuse-disconnect terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3626.2 ZTRK 2,5/4A/ZS BG 4044211059903 100 Disconnect-blade terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3605.2 ZTRK 2,5/4A/MT BG 4044211059699 100 Basic terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3611.2 ZTRK 2,5/4A/OT BG 4044211059750 100 Three-level initiator terminal | Multi-wire terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3590.2 ZIKD 2,5 BG 4044211059460 50 Three-level initiator terminal | Multi-wire terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3592.2 ZIKD 2,5/PE/L/L BG 4044211059507 50 Creation date 17.12.2023 08:55:42 Subject to technical changes 11 Data sheet 3712.5 ZQI 2,5/4 BU ##INVERSE##CONTA-CONNECT Three-level initiator terminal | Multi-wire terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3594.2 ZIKD 2,5/PE/L/N BG 4044211059538 50 ST Disconnect-blade terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3603.2 ZTRK 2,5/2A/MT BG 4044211059675 100 Disconnect-blade terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3604.2 ZTRK 2,5/3A/MT BG 4044211059682 100 Basic terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3609.2 ZTRK 2,5/2A/OT BG 4044211059736 100 Basic terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3610.2 ZTRK 2,5/3A/OT BG 4044211059743 100 Three-level initiator terminal | Multi-wire terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17037.2 ZIKD 2,5/L-L-N BG 4044211155742 50 ST Creation date 17.12.2023 08:55:42 Subject to technical changes 12 Data sheet 3712.5 ZQI 2,5/4 BU ##INVERSE##CONTA-CONNECT Double-level terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3564.2 ZRKD 2,5/N/DU 4044211059088 100 ST Double-level terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3566.2 ZRKD 2,5/N/PE 4044211059101 100 ST Double-level terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3575.2 ZRKD 2,5/ZBA BG 4044211059194 100 Three-level initiator terminal | Multi-wire terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3591.2 ZIKD 2,5/SV BG 4044211059484 50 Ex double-level terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1707.2 ZRKD 2,5 Ex BG 4044211110949 100 Double-level terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3562.2 ZRKD 2,5 BG 4044211151836 100 Creation date 17.12.2023 08:55:42 Subject to technical changes 13 Data sheet 3712.5 ZQI 2,5/4 BU ##INVERSE##CONTA-CONNECT Double-level terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3563.2 ZRKD 2,5/SV BG 4044211059064 100 Double-level terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3565.2 ZRKD 2,5/DU/PE 4044211059095 100 ST Double-level terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3576.2 ZRKD 2,5/SV/ZBA BG 4044211059217 100 Double-level terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3577.2 ZRKD 2,5/N/DU/ZBA 4044211059231 100 ST Double-level terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3578.2 ZRKD 2,5/DU/PE/ZBA 4044211059248 100 ST Double-level terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3579.2 ZRKD 2,5/N/PE/ZBA 4044211059255 100 ST Creation date 17.12.2023 08:55:42 Subject to technical changes 14 Data sheet 3712.5 ZQI 2,5/4 BU ##INVERSE##CONTA-CONNECT Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1704.2 ZRK 2,5/2A Ex BG 4044211058401 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3501.2 ZRK 2,5/3A BG 4044211151690 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1169.2 ZSRK 2,5/2A/SAS BG 4044211128647 100 Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 15/5.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1700.2 ZSRK 2,5/2A/15 Ex BG 4044211059354 100 Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1702.2 ZSRK 2,5/2A Ex BG 4044211059316 100 Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1705.2 ZRK 2,5/3A Ex BG 4044211110925 100 Creation date 17.12.2023 08:55:42 Subject to technical changes 15 Data sheet 3712.5 ZQI 2,5/4 BU ##INVERSE##CONTA-CONNECT Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3500.2 ZRK 2,5/2A BG 4044211151683 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3583.2 ZSRK 2,5/2A BG 4044211151874 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 15/5.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3585.2 ZSRK 2,5/2A/15 BG 4044211151904 100 Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1703.2 ZSRK 2,5/3A Ex BG 4044211059620 100 Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1706.2 ZRK 2,5/4A Ex BG 4044211058463 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 15/5.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3599.2 ZSRK 2,5/3A/15 BG 4044211152024 100 Creation date 17.12.2023 08:55:42 Subject to technical changes 16 Data sheet 3712.5 ZQI 2,5/4 BU ##INVERSE##CONTA-CONNECT Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 15/5.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1701.2 ZSRK 2,5/3A/15 Ex BG 4044211059590 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3502.2 ZRK 2,5/4A BG 4044211151713 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3600.2 ZSRK 2,5/3A BG 4044211152031 100 ##INVERSE##CONTA-CONNECT Double-level terminal with electronic components, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3568.2 ZRKD 2,5/LED1(RD)/24V DC BG 4044211059125 100 ST Creation date 17.12.2023 08:55:42 Subject to technical changes 17 Data sheet 3712.5 ZQI 2,5/4 BU ##INVERSE##CONTA-CONNECT Double-level terminal with electronic components, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour:Beige Article number Article name GTIN (EAN) Packaging unit 3570.2 ZRKD 2,5/D1 BG 4044211059149 100 ##INVERSE##CONTA-CONNECT Double-level terminal with electronic components, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3572.2 ZRKD 2,5/D3 BG 4044211059163 100 Creation date 17.12.2023 08:55:42 Subject to technical changes 18
3712.5 价格&库存
很抱歉,暂时无法提供与“3712.5”相匹配的价格&库存,您可以联系我们找货
  • 20+18.9030820+2.45020
