3717.5
3717.5
    CONTA-CLIP
    INSULATED CROSS CONNECTOR
3717.5 数据手册
Data sheet 3717.5 ZQI 2,5/9 BU Insulated cross-connector, No. of poles: 9, Mounting type: Plug in, Width: 44.8 mm, Rated cross-section: 2.5 mm², Colour: Blue RAL: Ähnlich 5005 Business data Article number 3717.5 Article name ZQI 2,5/9 BU GTIN (EAN) 4044211111328 Packaging unit 10 Quantity unit PC Weight per piece (not including packaging) 5.2 g Weight per piece (including packaging) 5.24 g Unit of weight G Customs number 85389099 Country of origin CZ Prio-Article 3717.8 Product description Insulated cross-connector Creation date 15.12.2023 02:11:06 Subject to technical changes 1 Data sheet 3717.5 ZQI 2,5/9 BU Technical data Dimensions Length 4.5 mm Width 44.8 mm Pitch size 5 mm Ratings Voltage with partition, max. 800 V Voltage without partition, max. 800 V Rated current 24 A Rated cross-section 2.5 mm² Contamination degree 3 Connection data No. of poles 9 Materials Material Copper alloy Surface Tin-plated Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Plug in Insulation available Touch protection is available Number of bridged terminals 9 Environmental Product Compliance REACH Candidate Substance Note Creation date 15.12.2023 02:11:06 No Subject to technical changes 2 Data sheet 3717.5 ZQI 2,5/9 BU Media Creation date 15.12.2023 02:11:06 Subject to technical changes 3 Data sheet 3717.5 ZQI 2,5/9 BU Accessories ##INVERSE##CONTA-CONNECT Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17481.2 ZST 2,5/1/1A/Q BG 4044211205201 50 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 66.3 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17493.2 ZST 2,5/13/1A/Q BG 4044211205324 10 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 71.4 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17494.2 ZST 2,5/14/1A/Q BG 4044211205331 10 ST Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3653.2 ZRKS 2,5/2A/2S BG 4044211177683 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3652.2 ZRKS 2,5/2A/1S BG 4044211177676 100 Feed-through terminal, Plug-in connection, Mounting type: Mounting rail TS 35/7.5, Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3655.2 ZRKS 2,5/2S BG 4044211177706 100 Creation date 15.12.2023 02:11:06 Subject to technical changes 4 Data sheet 3717.5 ZQI 2,5/9 BU ##INVERSE##CONTA-CONNECT Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 25.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17485.2 ZST 2,5/5/1A/Q BG 4044211205249 50 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 56.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17491.2 ZST 2,5/11/1A/Q BG 4044211205300 10 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 76.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17495.2 ZST 2,5/15/1A/Q BG 4044211205348 10 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 816 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17496.2 ZST 2,5/16/1A/Q BG 4044211205355 10 ST Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3650.2 ZRKS 2,5/1A/1S BG 4044211177652 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3651.2 ZRKS 2,5/1A/2S BG 4044211177669 100 Creation date 15.12.2023 02:11:06 Subject to technical changes 5 Data sheet 3717.5 ZQI 2,5/9 BU ##INVERSE##CONTA-CONNECT Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 45.9 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17489.2 ZST 2,5/9/1A/Q BG 4044211205287 25 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 51 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17490.2 ZST 2,5/10/1A/Q BG 4044211205294 25 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3673.2 ZST 2,5/1A/Q/Z BG 4044211177843 100 Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 20.4 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17484.2 ZST 2,5/4/1A/Q BG 4044211205232 50 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 35.7 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17487.2 ZST 2,5/7/1A/Q BG 4044211205263 25 ST Feed-through terminal, Plug-in connection, Mounting type: Mounting rail TS 35/7.5, Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3654.2 ZRKS 2,5/4S BG 4044211177690 100 Creation date 15.12.2023 02:11:06 Subject to technical changes 6 Data sheet 3717.5 ZQI 2,5/9 BU ##INVERSE##CONTA-CONNECT Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 10.2 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17482.2 ZST 2,5/2/1A/Q BG 4044211205218 50 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 15.3 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17483.2 ZST 2,5/3/1A/Q BG 4044211205225 50 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 40.8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17488.2 ZST 2,5/8/1A/Q BG 4044211205270 25 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 61.2 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17492.2 ZST 2,5/12/1A/Q BG 4044211205317 10 ST Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3672.2 ZST 2,5/1A/Q BG 4044211177836 100 Feed-through terminal, Tension-spring connection, Mounting type: Plug in, Rated crosssection: 2.5 mm², Width: 30.6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17486.2 ZST 2,5/6/1A/Q BG 4044211205256 25 ST Creation date 15.12.2023 02:11:06 Subject to technical changes 7 Data sheet 3717.5 ZQI 2,5/9 BU ##INVERSE##CONTA-CONNECT Feed-through terminal for direct mount, Tension-spring connection, Mounting type: Mounting surface, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 3638.2 ZSLN 2,5/2A-D BKYE 4044211080570 100 ST Feed-through terminal for direct mount, Tension-spring connection, Mounting type: Mounting surface, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 3639.2 ZSLN 2,5/2A-RC BKYE 4044211080556 100 ST Feed-through terminal for direct mount, Tension-spring connection, Mounting type: Mounting surface, Rated cross-section: 2.5 mm², Width: 11.1 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 3640.2 ZSLN 2,5/2A-D/F BKYE 4044211080563 50 ST Creation date 15.12.2023 02:11:06 Subject to technical changes 8
3717.5 价格&库存
很抱歉,暂时无法提供与“3717.5”相匹配的价格&库存,您可以联系我们找货
