Data sheet
3721.9 ZQI 4/3 RD
Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 16.2 mm, Rated cross-section: 4
mm², Colour: Red
Business data
Article number
3721.9
Article name
ZQI 4/3 RD
GTIN (EAN)
4044211111458
Packaging unit
50
Quantity unit
PC
Weight per piece (not including packaging)
2.04 g
Weight per piece (including packaging)
2.1 g
Unit of weight
G
Customs number
85389099
Country of origin
CZ
Prio-Article
3721.8
Product description
Creation date 15.12.2023 15:18:53
Subject to technical changes
1
Data sheet
3721.9 ZQI 4/3 RD
Technical data
Dimensions
Length
4.5 mm
Width
16.2 mm
Pitch size
6 mm
Ratings
Voltage with partition, max.
800 V
Voltage without partition, max.
800 V
Rated current
32 A
Rated cross-section
4 mm²
Contamination degree
3
Connection data
No. of poles
3
Materials
Material
Copper alloy
Surface
Tin-plated
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Mounting type
Plug in
Insulation available
Touch protection is available
Number of bridged terminals
3
Environmental Product Compliance
REACH Candidate Substance Note
No
2
Data sheet
3721.9 ZQI 4/3 RD
Media
3
Data sheet
3721.9 ZQI 4/3 RD
Accessories
4
Data sheet
3721.9 ZQI 4/3 RD
##INVERSE##CONTA-CONNECT
Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS
35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3515.2
ZRK 4/2A BG
4044211151751
100
Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type:
Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
1716.2
ZRK 4/2A Ex BG
4044211058579
100
Article number
Article name
GTIN (EAN)
Packaging
unit
1717.2
ZRK 4/3A Ex BG
4044211058609
100
Article number
Article name
GTIN (EAN)
Packaging
unit
3516.2
ZRK 4/3A BG
4044211151775
100
Article number
Article name
GTIN (EAN)
Packaging
unit
1718.2
ZRK 4/4A Ex BG
4044211058630
100
Article number
Article name
GTIN (EAN)
Packaging
unit
3517.2
ZRK 4/4A BG
4044211151782
100
5
很抱歉,暂时无法提供与“3721.9”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+12.3774450+1.59957
