3726.8
3726.8
    CONTA-CLIP
    INSULATED CROSS CONNECTOR
3726.8 数据手册
Data sheet 3726.8 ZQI 4/8 YE Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 46.7 mm, Rated cross-section: 4 mm², Colour: Yellow RAL: 1026 Business data Article number 3726.8 Article name ZQI 4/8 YE GTIN (EAN) 4044211060442 Packaging unit 10 Quantity unit PC Weight per piece (not including packaging) 5.83 g Weight per piece (including packaging) 5.92 g Unit of weight G Customs number 85389099 Country of origin CZ Prio-Article 3726.8 Product description Insulated cross-connector Creation date 15.12.2023 10:04:24 Subject to technical changes 1 Data sheet 3726.8 ZQI 4/8 YE Technical data Dimensions Length 4.5 mm Width 46.7 mm Pitch size 6 mm Ratings Voltage with partition, max. 800 V Voltage without partition, max. 800 V Rated current 32 A Rated cross-section 4 mm² Contamination degree 3 Connection data No. of poles 8 Materials Material Copper alloy Surface Tin-plated Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Plug in Insulation available Touch protection is available Number of bridged terminals 8 Environmental Product Compliance REACH Candidate Substance Note Creation date 15.12.2023 10:04:24 No Subject to technical changes 2 Data sheet 3726.8 ZQI 4/8 YE Media Creation date 15.12.2023 10:04:24 Subject to technical changes 3 Data sheet 3726.8 ZQI 4/8 YE Accessories Creation date 15.12.2023 10:04:24 Subject to technical changes 4 Data sheet 3726.8 ZQI 4/8 YE ##INVERSE##CONTA-CONNECT Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3515.2 ZRK 4/2A BG 4044211151751 100 Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1716.2 ZRK 4/2A Ex BG 4044211058579 100 Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1717.2 ZRK 4/3A Ex BG 4044211058609 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3516.2 ZRK 4/3A BG 4044211151775 100 Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1718.2 ZRK 4/4A Ex BG 4044211058630 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3517.2 ZRK 4/4A BG 4044211151782 100 Creation date 15.12.2023 10:04:24 Subject to technical changes 5
3726.8 价格&库存
很抱歉,暂时无法提供与“3726.8”相匹配的价格&库存,您可以联系我们找货
  • 10+34.4518210+4.44745
