3738.2
3738.2
    CONTA-CLIP
    接线端子 1x1P 自由悬挂(直插式)
3738.2 数据手册
Data sheet 3738.2 ZPL 1,5 BG Potential distribution strip, Tension-spring connection, Mounting type: Plug in, Rated cross-section: 1.5 mm², Width: 8.7 mm, Colour: Beige Business data Article number 3738.2 Article name ZPL 1,5 BG GTIN (EAN) 4044211060473 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 1.05 g Weight per piece (including packaging) 1.26 g Unit of weight G Customs number 85369010 Country of origin CZ Product description Potential distribution strip Colour Beige Creation date 17.12.2023 03:00:27 Subject to technical changes 1 Data sheet 3738.2 ZPL 1,5 BG Technical data Dimensions Length 12.9 mm Width 8.7 mm Height TS 35/7.5 17.5 mm Ratings Rated voltage 400 V Rated current 17.5 A Rated cross-section 1.5 mm² Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Tension-spring connection Connection position Top Connections 1 No. of poles 1 Wire cross-section single-core (rigid) / stranded, min. 0.5 mm² Wire cross-section single core (rigid)/stranded, max. 2.5 mm² Wire cross-section stranded, min. 0.5 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.5 mm² Wire cross-section stranded with wire-end ferrules, max. 1.5 mm² Wire cross-section AWG, min. 26 Wire cross-section AWG, max. 14 Stripping length 8 mm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 17.12.2023 03:00:27 Subject to technical changes 2 Data sheet 3738.2 ZPL 1,5 BG Technical data Further technical data Mounting type Plug in Gauge plug acc. to EN 60 947-1 A1 Can be mounted side-by-side Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 17.12.2023 03:00:27 Subject to technical changes 3 Data sheet 3738.2 ZPL 1,5 BG Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 300 V CSA Usegroup C: rated current 12,5 A CSA wire cross-section AWG, min. 26 CSA wire cross-section AWG, max. 14 CSA stripping length 8 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 300 V CSAus Usegroup C: rated current 12,5 A CSAus wire cross-section AWG, min. 26 CSAus wire cross-section AWG, max. 14 CSAus stripping length 8 mm cUL Recognized cUL approval C22.2 No 158 cUL Usegroup C: rated voltage 300 V cUL Usegroup C: rated current 12,5 A cUL wire cross-section single-core (rigid) AWG, min. 26 cUL wire cross-section single-core (rigid) AWG, max. 14 cUL wire cross-section stranded AWG, min. 26 cUL wire cross-section stranded AWG, max. 14 cUL wire material Cu cUL Recognized 1 Creation date 17.12.2023 03:00:27 Subject to technical changes 4 Data sheet 3738.2 ZPL 1,5 BG Approvals KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 400 V KEMA rated current 17,5 A KEMA rated impulse voltage 4 kV KEMA wire cross-section single core (rigid), min. 0.5 mm² KEMA wire cross-section single-core (rigid), max. 2.5 mm² KEMA wire cross-section stranded, min. 0.5 mm² KEMA wire cross-section stranded, max. 2.5 mm² UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 12,5 A UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 12,5 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 12,5 A UL wire cross-section single-core (rigid) AWG, min. 26 UL wire cross-section single-core (rigid) AWG, max. 14 UL wire cross-section stranded AWG, min. 26 UL wire cross-section stranded AWG, max. 14 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 17.12.2023 03:00:27 Subject to technical changes 5 Data sheet 3738.2 ZPL 1,5 BG Approvals DNV GL Approval DNV GL Certificate number TAE00000Y9 DNV GL Location Classes Temperature: B, Humidity: B, Vibration: A DNV GL approval granted 1 DNV GL rated cross-section 1.5 mm² DNV GL rated current 17,5 A DNV GL rated voltage 400 V DNV GL test standard IEC 60947-7-1:2009 DNV GL wire cross-section single-core (rigid), max. 2.5 mm² DNV GL wire cross-section stranded, max. 2.5 mm² Creation date 17.12.2023 03:00:27 Subject to technical changes 6 Data sheet 3738.2 ZPL 1,5 BG Media Creation date 17.12.2023 03:00:27 Subject to technical changes 7 Data sheet 3738.2 ZPL 1,5 BG Accessories Label holder Label holder, Pitch size: 5.1 mm, Colour: beige Article number Article name GTIN (EAN) Packaging unit 3786.2 ZBA 2 BG 4044211061128 50 ST Label holder, Pitch size: 5.1 mm, Colour: beige Article number Article name GTIN (EAN) Packaging unit 3787.2 ZBA 2/Z BG 4044211061135 50 ST Terminal blocks Initiator terminal / actuator terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3528.2 ZIZA 1,5/3 BG 4044211058722 100 ST Initiator terminal / actuator terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3530.2 ZIZA 1,5/3/LED(RD)/24V BG 4044211058746 50 ST Initiator terminal / actuator terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3533.2 ZIZA 1,5/4 BG 4044211058784 100 ST Creation date 17.12.2023 03:00:27 Subject to technical changes 8 Data sheet 3738.2 ZPL 1,5 BG Terminal blocks Initiator terminal / actuator terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3536.2 ZIZA 1,5/4/LED(RD)/24V BG 4044211058814 100 ST Initiator terminal / actuator terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 51 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3532.2 ZIZA 1,5/3/PE GNYE 4044211058777 20 ST Initiator terminal / actuator terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3537.2 ZIZA 1,5/4/PE GNYE 4044211058821 20 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1085.0 SDB 0,5x3,0 4044211014643 1 ST ##INVERSE##CONTA-CONNECT Initiator terminal / actuator terminal / block variant, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3535.2 ZIZA 1,5/4/B/LED(RD)/24V BG 4044211058807 50 ST Creation date 17.12.2023 03:00:27 Subject to technical changes 9 Data sheet 3738.2 ZPL 1,5 BG ##INVERSE##CONTA-CONNECT Initiator terminal / actuator terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3536.2 ZIZA 1,5/4/LED(RD)/24V BG 4044211058814 100 ST Creation date 17.12.2023 03:00:27 Subject to technical changes 10
3738.2 价格&库存
很抱歉,暂时无法提供与“3738.2”相匹配的价格&库存,您可以联系我们找货
