Data sheet
3756.2 ZAPD 2,5 BG
End plate, Width: 2 mm, Colour: Beige
Business data
Article number
3756.2
Article name
ZAPD 2,5 BG
GTIN (EAN)
4044211060664
Packaging unit
Quantity unit
PC
Weight per piece (not including packaging)
4.2 g
Weight per piece (including packaging)
4.29 g
Unit of weight
G
Customs number
85389099
Country of origin
DE
Prio-Article
3756.2
Product description
End plate
Creation date 16.12.2023 21:41:42
Subject to technical changes
1
Data sheet
3756.2 ZAPD 2,5 BG
Technical data
Dimensions
Length
83.6 mm
Width
2 mm
Height
43.2 mm
Materials
Material
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Designed as end plate
Snap-on available
Environmental Product Compliance
REACH Conform
Yes
REACH Candidate Substance Note
No
2
Data sheet
3756.2 ZAPD 2,5 BG
Media
3
Data sheet
3756.2 ZAPD 2,5 BG
Accessories
##INVERSE##CONTA-CONNECT
Double-level terminal with electronic components, Tension-spring connection, Mounting
type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour:
Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3568.2
ZRKD 2,5/LED1(RD)/24V DC BG
4044211059125
100 ST
Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3569.2
ZRKD 2,5/LED2(RD)/24V DC BG
4044211059132
100 ST
Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3572.2
ZRKD 2,5/D3 BG
4044211059163
100
Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3573.2
ZRKD 2,5/D4 BG
4044211059170
100
Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3574.2
ZRKD 2,5/D5 BG
4044211059187
100 ST
4
Data sheet
3756.2 ZAPD 2,5 BG
Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3645.2
ZRKD 2,5/LED(RD)/230V AC BG
4044211146733
100 ST
Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3570.2
ZRKD 2,5/D1 BG
4044211059149
100
Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3571.2
ZRKD 2,5/D2 BG
4044211059156
100
Ex protective-earth terminal ATEX-certified Tension-spring connection, Mounting type:
Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Greenyellow
Article number
Article name
GTIN (EAN)
Packaging
unit
1728.2
ZSLD 2,5 Ex GNYE
4044211126230
100 ST
Protective-earth double-level terminal, Tension-spring connection, Mounting type:
Article number
Article name
GTIN (EAN)
Packaging
unit
3567.2
ZSLD 2,5 GNYE
4044211059118
100 ST
5
Data sheet
3756.2 ZAPD 2,5 BG
Double-level terminal, Tension-spring connection, Mounting type: Mounting rail TS35/7.5,
Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3575.2
ZRKD 2,5/ZBA BG
4044211059194
100
Article number
Article name
GTIN (EAN)
Packaging
unit
3580.2
ZSLD 2,5/ZBA GNYE
4044211059262
100 ST
Ex double-level terminal ATEX-certified, Tension-spring connection, Mounting type:
Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
1707.2
ZRKD 2,5 Ex BG
4044211110949
100
Article number
Article name
GTIN (EAN)
Packaging
unit
3562.2
ZRKD 2,5 BG
4044211151836
100
Article number
Article name
GTIN (EAN)
Packaging
unit
3563.2
ZRKD 2,5/SV BG
4044211059064
100
6
Data sheet
3756.2 ZAPD 2,5 BG
Article number
Article name
GTIN (EAN)
Packaging
unit
3576.2
ZRKD 2,5/SV/ZBA BG
4044211059217
100
Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3570.2
ZRKD 2,5/D1 BG
4044211059149
100
7
