3758.5
3758.5
    CONTA-CLIP
    END PLATE
3758.5 数据手册
Data sheet 3758.5 ZAP SR/RC BU End plate, Width: 5.1 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 3758.5 Article name ZAP SR/RC BU GTIN (EAN) 4044211060763 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 2.2 g Weight per piece (including packaging) 2.3 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3758.2 Product description End plate Creation date 17.12.2023 08:53:35 Subject to technical changes 1 Data sheet 3758.5 ZAP SR/RC BU Technical data Dimensions Length 40 mm Width 5.1 mm Height 23.9 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 08:53:35 No Subject to technical changes 2 Data sheet 3758.5 ZAP SR/RC BU Media Creation date 17.12.2023 08:53:35 Subject to technical changes 3 Data sheet 3758.5 ZAP SR/RC BU Accessories ##INVERSE##CONTA-CONNECT Ex feed-through terminal for direct mount, ATEX-certified, Tension-spring connection, Mounting type: Mounting surface, Rated cross-section: 25 mm², Width: 51 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1729.2 ZSRK 2,5/2A-D Ex BG 4044211129699 100 ST Feed-through terminal for direct mount, Tension-spring connection, Mounting type: Mounting surface, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3588.2 ZSRK 2,5/2A-D BG 4044211151966 100 Feed-through terminal for direct mount, Tension-spring connection, Mounting type: Mounting surface, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3587.2 ZSRK 2,5/2A-RC BG 4044211151942 100 ##INVERSE##CONTA-CONNECT Creation date 17.12.2023 08:53:35 Subject to technical changes 4
3758.5 价格&库存
很抱歉,暂时无法提供与“3758.5”相匹配的价格&库存,您可以联系我们找货
