Data sheet
3760.1 ZAP 6/2A GN
End plate, Width: 2 mm, Colour: Green
Business data
Article number
3760.1
Article name
ZAP 6/2A GN
GTIN (EAN)
4044211060800
Packaging unit
Quantity unit
PC
Weight per piece (not including packaging)
3.8 g
Weight per piece (including packaging)
3.9 g
Unit of weight
G
Customs number
85389099
Country of origin
DE
Prio-Article
3760.2
Product description
End plate
Creation date 15.12.2023 09:27:06
Subject to technical changes
1
Data sheet
3760.1 ZAP 6/2A GN
Technical data
Dimensions
Length
65 mm
Width
2 mm
Height
40 mm
Materials
Material
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Designed as end plate
Snap-on available
Environmental Product Compliance
REACH Conform
Yes
REACH Candidate Substance Note
No
2
Data sheet
3760.1 ZAP 6/2A GN
Media
3
Data sheet
3760.1 ZAP 6/2A GN
Accessories
##INVERSE##CONTA-CONNECT
Protective earth terminal, Tension-spring connection, Mounting type: Mounting rail TS
35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Green-yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3589.2
ZSL 6/2A GNYE
4044211151973
100 ST
Ex protective-earth terminal ATEX-certified Tension-spring connection, Mounting type:
Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Greenyellow
Article number
Article name
GTIN (EAN)
Packaging
unit
1725.2
ZSL 6/2A Ex GNYE
4044211059453
100 ST
Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type:
Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
1719.2
ZRK 6/2A Ex BG
4044211059279
100
Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS
Article number
Article name
GTIN (EAN)
Packaging
unit
3581.2
ZRK 6/2A BG
4044211151867
100
4
很抱歉,暂时无法提供与“3760.1”相匹配的价格&库存,您可以联系我们找货
