3760.8
3760.8
    CONTA-CLIP
    END PLATE
3760.8 数据手册
Data sheet 3760.8 ZAP 6/2A YE End plate, Width: 2 mm, Colour: Yellow RAL: 1026 Business data Article number 3760.8 Article name ZAP 6/2A YE GTIN (EAN) 4044211108106 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 3.8 g Weight per piece (including packaging) 3.9 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3760.2 Product description End plate Creation date 16.12.2023 12:45:24 Subject to technical changes 1 Data sheet 3760.8 ZAP 6/2A YE Technical data Dimensions Length 65 mm Width 2 mm Height 40 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 12:45:24 No Subject to technical changes 2 Data sheet 3760.8 ZAP 6/2A YE Media Creation date 16.12.2023 12:45:24 Subject to technical changes 3 Data sheet 3760.8 ZAP 6/2A YE Accessories ##INVERSE##CONTA-CONNECT Protective earth terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3589.2 ZSL 6/2A GNYE 4044211151973 100 ST Ex protective-earth terminal ATEX-certified Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Greenyellow Article number Article name GTIN (EAN) Packaging unit 1725.2 ZSL 6/2A Ex GNYE 4044211059453 100 ST Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1719.2 ZRK 6/2A Ex BG 4044211059279 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3581.2 ZRK 6/2A BG 4044211151867 100 Creation date 16.12.2023 12:45:24 Subject to technical changes 4
3760.8 价格&库存
很抱歉,暂时无法提供与“3760.8”相匹配的价格&库存,您可以联系我们找货
