3761.2
3761.2
    CONTA-CLIP
    END PLATE
3761.2 数据手册
Data sheet 3761.2 ZAP 2,5/ID BG End plate, Width: 1.5 mm, Colour: Beige Business data Article number 3761.2 Article name ZAP 2,5/ID BG GTIN (EAN) 4044211060855 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 6.2 g Weight per piece (including packaging) 6.39 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3761.2 Product description End plate Creation date 16.12.2023 21:41:54 Subject to technical changes 1 Data sheet 3761.2 ZAP 2,5/ID BG Technical data Dimensions Length 116 mm Width 1.5 mm Height 60.2 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Conform Yes REACH Candidate Substance Note No Creation date 16.12.2023 21:41:54 Subject to technical changes 2 Data sheet 3761.2 ZAP 2,5/ID BG Media Creation date 16.12.2023 21:41:54 Subject to technical changes 3 Data sheet 3761.2 ZAP 2,5/ID BG Accessories ##INVERSE##CONTA-CONNECT Three-level initiator terminal | Multi-wire terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3590.2 ZIKD 2,5 BG 4044211059460 50 Three-level initiator terminal | Multi-wire terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3592.2 ZIKD 2,5/PE/L/L BG 4044211059507 50 Three-level initiator terminal | Multi-wire terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3593.2 ZIKD 2,5/SV/PE GNYE 4044211059521 50 ST Three-level initiator terminal | Multi-wire terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3594.2 ZIKD 2,5/PE/L/N BG 4044211059538 50 ST Three-level initiator terminal | Multi-wire terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17037.2 ZIKD 2,5/L-L-N BG 4044211155742 50 ST Creation date 16.12.2023 21:41:54 Subject to technical changes 4 Data sheet 3761.2 ZAP 2,5/ID BG ##INVERSE##CONTA-CONNECT Three-level initiator terminal | Multi-wire terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3591.2 ZIKD 2,5/SV BG 4044211059484 50 Creation date 16.12.2023 21:41:54 Subject to technical changes 5
3761.2 价格&库存
很抱歉,暂时无法提供与“3761.2”相匹配的价格&库存,您可以联系我们找货
