3762.5
3762.5
    CONTA-CLIP
    END PLATE
3762.5 数据手册
Data sheet 3762.5 ZAP MA BU End plate, Width: 1.5 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 3762.5 Article name ZAP MA BU GTIN (EAN) 4044211108144 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 6.4 g Weight per piece (including packaging) 6.57 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3762.2 Product description End plate Creation date 17.12.2023 08:51:51 Subject to technical changes 1 Data sheet 3762.5 ZAP MA BU Technical data Dimensions Length 86.4 mm Width 1.5 mm Height 17.6 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 08:51:51 No Subject to technical changes 2 Data sheet 3762.5 ZAP MA BU Media Creation date 17.12.2023 08:51:51 Subject to technical changes 3 Data sheet 3762.5 ZAP MA BU Accessories ##INVERSE##CONTA-CONNECT Motor-connection terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3582.2 ZVMAK 2,5 BG 4044211059309 50 Motor-connection terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3646.2 ZVMAK 2,5 N/L/L/PE BG 4044211171322 50 ST Creation date 17.12.2023 08:51:51 Subject to technical changes 4
3762.5 价格&库存
很抱歉,暂时无法提供与“3762.5”相匹配的价格&库存,您可以联系我们找货
