Data sheet
3767.8 ZQI 6/6 YE
Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 48.1 mm, Rated cross-section: 6
mm², Colour: Yellow
RAL: 1026
Business data
Article number
3767.8
Article name
ZQI 6/6 YE
GTIN (EAN)
4044211060930
Packaging unit
Quantity unit
PC
Weight per piece (not including packaging)
10.2 g
Weight per piece (including packaging)
10.4 g
Unit of weight
G
Customs number
85389099
Country of origin
CZ
Product description
Colour
Yellow
Creation date 17.12.2023 08:52:13
Subject to technical changes
1
Data sheet
3767.8 ZQI 6/6 YE
Technical data
Dimensions
Length
7 mm
Width
48.1 mm
Pitch size
8 mm
Ratings
Voltage with partition, max.
800 V
Voltage without partition, max.
800 V
Rated current
41 A
Rated cross-section
6 mm²
Contamination degree
3
Connection data
No. of poles
6
Materials
Material
Copper alloy
Surface
Tin-lead
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Mounting type
Plug in
Insulation available
Touch protection is available
Number of bridged terminals
6
Environmental Product Compliance
REACH Conform
yes
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
RoHS Conform
yes
2
Data sheet
3767.8 ZQI 6/6 YE
Media
3
Data sheet
3767.8 ZQI 6/6 YE
Accessories
##INVERSE##CONTA-CONNECT
Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type:
Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
1719.2
ZRK 6/2A Ex BG
4044211059279
100
Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS
Article number
Article name
GTIN (EAN)
Packaging
unit
3581.2
ZRK 6/2A BG
4044211151867
100
4
很抱歉,暂时无法提供与“3767.8”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 20+44.3347420+5.72325
