3786.2
3786.2
    CONTA-CLIP
    MARKING ADAPTER
3786.2 数据手册
Data sheet 3786.2 ZBA 2 BG Label holder, Pitch size: 5.1 mm, Colour: beige Business data Article number 3786.2 Article name ZBA 2 BG GTIN (EAN) 4044211061128 Packaging unit 50 Quantity unit PC Number of markers per row 1 ST Weight per piece (not including packaging) 0.6 g Weight per piece (including packaging) 0.62 g Unit of weight G Customs number 85389099 Country of origin DE Product description Label holder Colour Beige Creation date 14.12.2023 18:57:23 Subject to technical changes 1 Data sheet 3786.2 ZBA 2 BG Technical data Dimensions Pitch size 5.1 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Halogen-free Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 14.12.2023 18:57:23 Subject to technical changes 2 Data sheet 3786.2 ZBA 2 BG Media Creation date 14.12.2023 18:57:23 Subject to technical changes 3 Data sheet 3786.2 ZBA 2 BG Accessories Markers Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4600.7 PMC SB 5/50 WH 4044211088903 500 ST ##INVERSE##CONTA-CONNECT Marshalling rack, Plug in, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3596.2 ZMP 1,5 BG 4044211059552 50 ST Potential distribution strip, Tension-spring connection, Mounting type: Plug in, Rated cross-section: 1.5 mm², Width: 8.7 mm, Colour: Red-brown Article number Article name GTIN (EAN) Packaging unit 3739.6 ZPL 1,5 RB 4044211060480 100 Potential distribution strip, Tension-spring connection, Mounting type: Plug in, Rated cross-section: 1.5 mm², Width: 8.7 mm, Colour: Blue Article number Article name GTIN (EAN) Packaging unit 3742.5 ZPL 1,5 BU 4044211060510 100 ST Potential distribution strip, Tension-spring connection, Mounting type: Plug in, Rated cross-section: 1.5 mm², Width: 8.7 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3743.2 ZPL 1,5/PE GNYE 4044211060527 100 ST Creation date 14.12.2023 18:57:23 Subject to technical changes 4 Data sheet 3786.2 ZBA 2 BG ##INVERSE##CONTA-CONNECT Potential distribution strip, Tension-spring connection, Mounting type: Plug in, Ratedcrosssection: 1.5 mm², Width: 8.7 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3791.8 ZPL 1,5 YE 4044211061197 100 ST Potential distribution strip, Tension-spring connection, Mounting type: Plug in, Rated cross-section: 1.5 mm², Width: 8.7 mm, Colour: Green Article number Article name GTIN (EAN) Packaging unit 3792.1 ZPL 1,5 GN 4044211061203 100 ST Potential distribution strip, Tension-spring connection, Mounting type: Plug in, Rated cross-section: 1.5 mm², Width: 8.7 mm, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 3793.3 ZPL 1,5 OG 4044211061210 100 ST Initiator terminal / actuator terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3528.2 ZIZA 1,5/3 BG 4044211058722 100 ST Initiator terminal / actuator terminal / block variant, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3529.2 ZIZA 1,5/3/B BG 4044211058739 50 Initiator terminal / actuator terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3530.2 ZIZA 1,5/3/LED(RD)/24V BG 4044211058746 50 ST Creation date 14.12.2023 18:57:23 Subject to technical changes 5 Data sheet 3786.2 ZBA 2 BG ##INVERSE##CONTA-CONNECT Initiator terminal / actuator terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3533.2 ZIZA 1,5/4 BG 4044211058784 100 ST Initiator terminal / actuator terminal / block variant, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3535.2 ZIZA 1,5/4/B/LED(RD)/24V BG 4044211058807 50 ST Potential distribution strip, Tension-spring connection, Mounting type: Plug in, Rated cross-section: 1.5 mm², Width: 8.7 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3738.2 ZPL 1,5 BG 4044211060473 100 ST Initiator terminal / actuator terminal / block variant, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3531.2 ZIZA 1,5/3/B/LED(RD)/24V BG 4044211058760 50 ST Initiator terminal / actuator terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3536.2 ZIZA 1,5/4/LED(RD)/24V BG 4044211058814 100 ST Creation date 14.12.2023 18:57:23 Subject to technical changes 6 Data sheet 3786.2 ZBA 2 BG ##INVERSE##CONTA-CONNECT Initiator terminal / actuator terminal / block variant, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour:Beige Article number Article name GTIN (EAN) Packaging unit 3534.2 ZIZA 1,5/4/B BG 4044211058791 50 ST ##INVERSE##CONTA-CONNECT Marshalling rack, Plug in, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3596.2 ZMP 1,5 BG 4044211059552 50 ST ##INVERSE##CONTA-CONNECT Potential distribution strip, Tension-spring connection, Mounting type: Plug in, Rated cross-section: 1.5 mm², Width: 8.7 mm, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 3793.3 ZPL 1,5 OG 4044211061210 100 ST ##INVERSE##CONTA-CONNECT Initiator terminal / actuator terminal / block variant, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3535.2 ZIZA 1,5/4/B/LED(RD)/24V BG 4044211058807 50 ST ##INVERSE##CONTA-CONNECT Creation date 14.12.2023 18:57:23 Subject to technical changes 7 Data sheet 3786.2 ZBA 2 BG Initiator terminal / actuator terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3528.2 ZIZA 1,5/3 BG 4044211058722 100 ST Creation date 14.12.2023 18:57:23 Subject to technical changes 8
3786.2 价格&库存
很抱歉,暂时无法提供与“3786.2”相匹配的价格&库存,您可以联系我们找货
