3795.5
3795.5
    CONTA-CLIP
    END PLATE
3795.5 数据手册
Data sheet 3795.5 ZAP SR 3A/35 BU End plate, Width: 1.6 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 3795.5 Article name ZAP SR 3A/35 BU GTIN (EAN) 4044211061296 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 1.9 g Weight per piece (including packaging) 1.95 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3795.2 Product description End plate Creation date 17.12.2023 09:03:32 Subject to technical changes 1 Data sheet 3795.5 ZAP SR 3A/35 BU Technical data Dimensions Length 54.2 mm Width 1.6 mm Height 28.7 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 09:03:32 No Subject to technical changes 2 Data sheet 3795.5 ZAP SR 3A/35 BU Media Creation date 17.12.2023 09:03:32 Subject to technical changes 3 Data sheet 3795.5 ZAP SR 3A/35 BU Accessories ##INVERSE##CONTA-CONNECT Ex protective-earth terminal ATEX-certified Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Greenyellow Article number Article name GTIN (EAN) Packaging unit 1712.2 ZSLN 2,5/3A Ex GNYE 4044211059668 100 ST Protective earth terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3602.2 ZSLN 2,5/3A GNYE 4044211152055 100 ST Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1703.2 ZSRK 2,5/3A Ex BG 4044211059620 100 Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3600.2 ZSRK 2,5/3A BG 4044211152031 100 Creation date 17.12.2023 09:03:32 Subject to technical changes 4
3795.5 价格&库存
很抱歉,暂时无法提供与“3795.5”相匹配的价格&库存,您可以联系我们找货
    • 50+6.3686650+0.79895
